See my comments in bold.
Hope this helps. Don't forget some POP (Pool Owner Patience)...
tracyd21 said:I did not add any CYA. I bought 15 lbs though.
Maybe you can return it then. Or keep it for future use, it has a long shelf life if stored properly. 50 may not even be accurate.
What are CCs?
Read the ABCs of Pool Water Chemistry in Pool School.
If no one is able to dump in chlorine, do I not chlorinate it at all? And I take the floater out altogether?
Pouring in bleach would be preferred, if you have no one to do that, then leave the pool uncovered and use a floater. I think you will lose progress though, despite the tablets.
For consistency's sake, i tested with a test strip to see what it said for CYA. The color chart indicates somewhere between 50 and 100 now. I don't know how this happened.
Test strips and Pool Store tests are notoriously inaccurate, which is why we advocate owning your own test kit, either the TF100 or the Taylor K-2006.
By shocking, you mean just adding bleach, right?
Yes. Read "How to Shock your Pool" in Pool School.
Sorry, I've read all the info several times, but I am sure what you mean when you say "shock up to 20" -
20 FC is your shock level - you add enough bleach to reach 20. If you look at the CYA chart you have 3 numbers corresponding to your CYA level (50). Your minimum, which is 4, your target, which is 6 (these numbers are for everyday chlorination) and 20 which is your shock level. To kill algae, you raise your FC with bleach up to shock level and hold it there with frequent bleach additions, until the 20 holds overnight.
I am looking at the pool calculator and can't figure out how much bleach would bring me to 20 (and I have no clue what the number 20 means).
If you put in your gallons in the size box, then "2" in the "now" column, and "20" in the "Target" column, I get 3.9 jugs (182oz) size to raise your FC to 20.
Ahhh! This is why I didn't want a pool
You'll come to love it.
