Thread: Advice replacing a Pentair Face Ring
    Mar 2017
    Weston
    3
    Exclamation Advice replacing a Pentair Face Ring
    Hello,
    I have an old Face Ring Assembly like the one on the picture with most of the pieces that tight the light broken.
    So I wonder if it would be possible for me to upgrade to a Wire Clamp Face Ring without replacing the whole fixture.
    I would really appreciate any guidance on this...
    Thanks!
    30,941
    Re: Advice replacing a Pentair Face Ring
    I would call Pentair and see if there is an "upgrade" kit available.
    InyoRob's Avatar
    Feb 2017
    Longwood/FL
    97
    You can upgrade the Amerlite face ring to the wire clamp version. You would need to get the face ring (79110600) and the clamp assembly (79111000). I would also recommend replacing the lens gasket when you install the new face ring; 79101600.
    Mar 2017
    Weston
    3
    Thanks a lot for your help.
    I will try them and state my results here for others.
