Results 1 to 17 of 17
Thread: Narrowing down to a couple Robotic Cleaners, please help
    Mar 2015
    MO
    86
    Hello, I think I have given myself paralysis by analysis on robotic cleaners.
    Here is what I know is important to me:
    Ease of use
    As low of maintenance as possible.
    Functions properly in my pool
    Reliable
    I am willing to pay more to get the above
    Our pool is Pebble Tech, deep end is about 11 feet at it's deepest, and in the deepest area, it is very square from the floor of the pool to the wall. There are two benches, and also a set of three stairs. The pool also has swim up bar seats, which are basically concrete columns.
    Two years ago we bought a Polaris 280, which did not really work well at all for us, the bag would fill up easily, the bag was not easy to empty. Worse, it would constantly tangle itself around the bar seats. Then, our booster pump went bad. I don't want to continue to invest in the Polaris 280.
    The Robotic Cleaners are intriguing, but there are so many options and models, it is hard to decide.
    I need at least a 55 foot cord, and might just want a 70 foot cord to be sure.
    I don't want it to get stuck near or around the bar stools.
    I don't want a bag system (back to ease of use).
    Dolphin and Pentair are both carried by local pool companies, and I could test a Dolphin.
    The Dolphins intrigue me because the fine mesh filter sits just inside the regular filter.
    I am not sure I need all the features of some of the higher end Pentair and Dolphin Models.
    Open to advice and experience, and happy to answer any questions - thanks!
    In Ground Pool, ~40k gallons, Pebble Tech, Intelliflo iQ60 SWG, RayPak 406 Gas Heater, Sand Filter, Variable Speed pump, seems to get alot of sun, but no debri. built in 2006. TFT XL Test Kit, with SpeedStir. Water from hose March.2017 used to fill FC=0, pH=7.2, CH= 375-400, TA=240.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Narrowing down to a couple Robotic Cleaners, please help
    Lots of folks, including me, are happy with the Doheny's Discovery, aka Maytronics S200, aka Dolphin Triton Plus. More in pool thread and here, First Robotic Cleaner, Doheny's Discovery
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Got a dolphin last year and I love it. It's a obviously just a different concept than the Polaris. I love the "leave in the pool" aspect of the Polaris, but that's about it.
    The Dolphin is great, but you have to get it out, unwind the cord, plug in the control box, etc. Then you have to come back a few hours later and put it all back up. Pay me now or pay me later I guess but I'm not constantly trying to get it to work right like I am my Polaris. It does a great job at cleaning my pool.
    Memphis, TN.
    Pool IG, 20K gallon, Gunite. Triton Sand filter, Pentair Pump, Polaris 280, Doheny Discovery Dolphin, Chlorinating Liquid, Rock Water Feature, New Plaster 2015
    Spa 450 gal, Tropic Seas Waikiki 864L, Bromine
    Taylor K-2006
    tucsontico's Avatar
    Mar 2014
    227
    I bought a Dolphin Nautilus XL 2 years ago–even though I have an in-floor cleaning system. The Dolphin does a great job in my freeform pool! Actually it brushes and cleans much better than I can. I really like the top mounted filter packs and the fine mesh filters pick up stuff I cannot even see from the bottom and sides. Like Bigdog43 said, you have to plug it in and retrieve it but that is so much less trouble than brushing yourself!
    19,500 gal, 16' x 38' PebbleTec IG Pool, Built 4/2013; Pentair IntelliFlo VS 3050 3 HP Pump, Pentair Intellichlor IC40 SWG, Pentair IntellipH, Pentair 520 sq ft/150 GPM Cartridge Filter, A&A In-Floor Cleaner, Dolphin Nautilus Plus Robot (aka "Robbie"), Pentair EasyTouch Power Panel w/ Quick Touch 4 Remote Control, Autelis WiFi controller, Clear 12 mil Solar Cover on Presto SS Reel, Taylor K-2006 Test Kit.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    As always, I am in love with my Dolphin M5/500. It's top of the line, and will be replaced in kind the day it finally does give it up. Fourth season this year, and runs like a champ, never a problem.
    We have a new member here with a very large 60K gallon pool, and she is in love with hers too.
    Essential Links:
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,265
    R,
    While I'm very pro robots, I doubt you will find one that can get around your column issue. If there is enough space for the robot to get around the column, I would have to assume it will, from time to time, wrap the card around the column.
    If your pool company has one you can try, that would be your best bet.
    Thanks for posting,
    DFW, TX
    24,974
    Quote Originally Posted by Bigdog43 View Post
    The S series robots have a weekly timer, you can program to run daily, 3x/wk or 4x/wk and it shuts off after a week. My robot stays in my pool spring and fall.
    Paul & Crystal's Avatar
    May 2014
    Oklahoma City, OK
    539
    I am the other Dolphin M500 lover. It does a great job. It comes with a set of large debris filters and a set of fine. They are easy to change out. The large just need a rinse. I always soak my fine in a warm bath after running and give them some extra spraying to get at the accordion pleats. This model has a great cart which I would not be without. It also has a remote which I have not used yet but I'm sure I will eventually. I have large pool and always run the three hour cycle.
    Testing a Dolphin out in your pool would be great.
    Best of luck in your search!
    Crystal
    60K 53 X 23 X 3'-10' IG Grecian Concrete aka "The Beast"
    TF100 XL with Speed Stir
    Dolphin M500 aka "The Beast Master"
    Sta Rite Max E Pro 2 HP - Hayward Pro Series Sand Filter S310T.
    My Pool Thread: Old School Pool
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Quote Originally Posted by pooldv View Post
    What?!?!?
    That's what I have. For some reason I thought I read it wasn't good to leave it in the pool. This is great news!
    Memphis, TN.
    Taylor K-2006
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    I leave mine in all the time, it comes out for swims and good weather periods, but like PoolDV, same for me.
    Essential Links:
    Mar 2015
    MO
    86
    Thanks All, I rented a Dolphin M5 for the weekend, fifty bucks, and my pool needed it! I like the unit. I have been running it for about 2 hours, it got stuck once in an area I am concerned about, the pool has 6 swim up bar seats, which are basically concrete columns. It also seemed to have trouble getting out of the deep end and into the shallow, as that is a very steep slope, I just empty the filters, and we will see if it now has the power to climb now.
    Thanks everyone for the feedback.
    Mar 2015
    MO
    86
    Here is my review of the Dolphin M5 in my pool, I am sharing this to make sure I am not making a user error, and also in case someone has a better recommendation.
    My pool is odd shape, has two benches and 6 bar stools. The deep end is rather deep, around 11 feet. Pebble Tec. I ran the unit 5 times, three times with normal filters, twice with the fine filter.
    Here is what I liked about the Dolphin M5.
    - it did a really good job cleaning, and it got around to all areas (especially when filters were relatively clean.
    - the chord stay untangled or twisted up. It kind of floats on the water, and drops down to the unit while it operates.
    - it has a normal and fine filter.
    - the filters are not too difficult to clean
    What I am concerned about for my pool/situation.
    - it did not climb the wall at all, and as such it did not do the pool edge, I only saw it get up one of the three steps.
    - the unit is very heavy when pulling it up out of the water, and it seemed like the water that was releasing into the pool as I lifted was quite dirty/cloudy.
    - the filters are not difficult to clean, but I think they could/should be easier, and it would be great if the normal and fine filter worked together at the same time.
    - it found it's way in between the bar stools twice in the ~8 hours I used it. Not awful, but not ideal.
    I don't want to give the wrong impression, the M5 worked really well, and I could work around the concerns I have (I could brush the walls and steps to knock stuff down to the floor, un trap it from the bar stools occassionaly, etc...). However, I researched the Dolphin s300 and s300i online, and it looks like this unit should solve 3 of the 4 concerns I have, obviously won't know how it would handle bar stools until I tried it. My guess is the bar stools are all about the width of the unit. The M5 is pretty wide, and only got stuck twice in 8 hours, not bad.... Unless some unit has some super intelligence to sense bar stools, i think this is just the way it is.
    I greatly appreciate all the input, if anyone has any thoughts on my situation, I would appreciate it.
    el duderino's Avatar
    Jun 2008
    Austin, TX
    118
    Thanks for the review. I have 3 barstools, so I share your concern and appreciate hearing a real-world report on that!
    Our pool- (Completed March 2009)
    20k gallons, 38x15 Free Form Gunite (3.5'-8'), 26' Negative Edge and 7' Negative Edge spa with blower, Midnight Blue Diamondbrite, AquaLogic PS-8 control, Goldline Salt Chlorine Generator, 2x1.5hp Pentair 2 speed pumps, Pentair DE Filter, Pentair 400k BTU Heater, and BlackMaxPolaris 280 w/ Hayward booster pump, Pentair Prowler 920, DIY Stenner Chlorinator
    Oct 2007
    Parkland, FL
    753
    The m5 can zero turn. I don't believe the s series can do that which would likely make the problem worse. If the width is an issue. The commercial Cleaners are wider. Though typically more expensive.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Aug 2016
    Riverside, CA
    378
    Quote Originally Posted by ramsfan View Post
    Just wondering..
    I love the concept of a swim up bar. As a matter of fact we almost bought a house with a pool with one, but then I thought, "Wait, who's going to be on the other side? This isn't Mexico so that'll be me."
    So, who is on the other side?
    DFW, TX
    24,974
    Exactly! Not only do you need someone on the other side but they have to make good drinks!
    Mar 2015
    MO
    86
    Well, we bought a house that had one. it is correct someone needs to be on the other side to get drinks, and what not, but it seems like people kind of take turns. our dog LOVES the bar stools, so that works too...
    Honestly, I thought there were kind of something that would just be a novelty, but they get a lot of use, as they are shaded at times when the pool is sunny, so it draws a lot of hanging out. We love them.
