Results 1 to 7 of 7
Thread: Bathtub Ring after replaster
    Jan 2013
    The Colon(y), Tx
    47
    Hello O' Oracle of TFP!
    We have a 15k freeform that was built in '96. We had it re plastered with 30% blue quartz and smooth plaster last year around this time. I overall am very happy with it, but I do have a ring from when it was filling. I don't recall the water being shut off, but its been a year and it could have happened I suppose. It really densest bother me too much, but if I can do something about it without draining the pool and/or spending lotsa money, I'll give it a go. I used a friend for the work and prefer to not involve them since they did me right in all other aspects of this job.
    So my question is: is there a way to scrub (pumice, stainless brush, etc.) the bathtub ring to make it blend better? Is there another approach that works?
    Please see pics (sorry for the crude overlay, but wanted to highlight the ring - which runs through the text boxes).
    Thanks for the help!
    15k in-ground pool, plaster, Aquapure 1400 (whole new cell/cables/sensor 5/25/15), Pentaire Cartridge filter, Ruud heater(2/13), Polaris 360 pressure side cleaner (10/14), some other stuff...
    Jul 2011
    Arizona & California
    833
    Re: Bathtub Ring after replaster
    It is next to impossible to blend in effectively, but using 100 grit wet/dry sandpaper may improve it. And this will work best under water. Good luck, it will require a lot of sanding.
    Jan 2013
    The Colon(y), Tx
    47
    interesting. I might do a section with each swim. May take me all summer, but what's a few minutes a swim to work up some relaxation reward. Thanks for sharing.
    If theres another way, I'm all ears though.
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Harbor freight has some decent air powered sanders - DA, orbital, etc - for under $40. Do you have a decently sized air compressor? I wonder how well it would work under water? Cheap enough that if it doesn't work out, or you wreck it trying it's not a huge loss...
    Chris | 16' x 34' 16,000 gallon | IG Vinyl | Pentair Tagelus sand filter | Jandy 2hp epump | AquaPro PRO1300 heat pump | Coverstar auto cover | Taylor K-2006 | built August, 2016.
    Jan 2013
    The Colon(y), Tx
    47
    I do have a 60gal compressor, so that might could work. I'm not afraid of wrecking a HF special, but what risk would be ther ewith the plaster by doing it with power tools? Have you done this before?
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    170
    Quote Originally Posted by NorthOfDallas View Post
    Nope - just an idea based on the other reply... I'm always about power tools, but you probably don't want to take an electric sander in with you, lol...
    Jan 2013
    The Colon(y), Tx
    47
    Quote Originally Posted by cjpwalker View Post
    I thought about swimming with the electric DA, but I was worried about the bearings
