Thread: New Pool Build Finish
    Apr 2017
    Florida
    2
    Hello,
    First time poster here with a few questions. I've dug through the forums a bit educating myself more about new pool installations but, still had some decisions that we needed feedback on.
    We are currently deciding on a new build between two PB (was originally 3) in the south Florida area. The builds are very similar with a just a few small differences.
    The overall build:
    - 32x17 (86 LF) (free form design) 3ft-5ft depth
    - 13x7 Sunshelf with LED light, bubbler and umbrella sleeve
    - 6ft bench in deeper end of the pool
    - 2 x LED lights (1 included from builders)
    - 1.5 HP pump (Pentair or Jandy)
    - Salt System (same brands)
    - Pre-wire/plumbing for Heater
    - 600 sqft paver install (we are in a zero lot line community so we are a little limited)
    - Pool Finish - one builder is standard plaster finish with choice of color and the other includes a quartz cement aggregate.
    The overall price difference between the two is about $1475, the PB featuring the Quartz finish being more expensive at $32,652.
    My question is if the Quartz finish is worth that amount?
    As side item, I researched the benefits of Quartz and PT finishes as far as it relates to potential durability benefits when properly cared for but, when I called the company that the PB uses to lay the Quartz finish they told me it was just for aesthetics and still only offered a 10 year warranty (same as the other builder on their standard plaster finish). I know warranty coverages can vary.
    Does that sound right or?
    Thank you for your time.
    TxBwana's Avatar
    Mar 2017
    Plano, TX
    73
    Re: New Pool Build Finish
    Can't say anything as regards your particular quartz finish, but the pool at our house had a Diamond Brite quartz finish applied in 1998 when we moved in in 2002, and we are just this year replastering... and it could have probably waited another year. That's 20 years.
    So to me, it would be worth the difference. We are going with a Wet Edge pebble finish this time.
    15k IG gunite, built 1999, RiverBend Sandler, attached spa, Dolphin S200, Pentair Triton II sand filter, Wet Edge Prism Matrix in Constellation with extra ocean shells handcast, Pentair MasterTemp 400, my remodel
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,310
    H,
    Welcome to TFP... A Great resource for all new pool owners...
    3' is just not deep enough, even for the shallow end. I would go 3.5' or 4' minimum.
    Might want to consider going with a Variable speed pump, they can make a huge difference in your electrical bills.
    You will love your new saltwater pool... !!
    Thanks for posting,
    pikeman's Avatar
    Jul 2008
    Pflugerville, Texas
    68
    +1 on Wet Edge Technology. Their middle range materials are not much more than the cheapest alternative and a huge improvement. I used it this last year and at one year am very happy with our choice.
    Pete
    20K IG, WetEdge technology lined pool, TF100 Test Kit, CircuPool RJ60+, StaRite pump, Hayward DE filter, Hayward Navigator pool vac. Zodiac MX8 vacuum thrown in garbage.
