Thread: Yellow Stain in Spa
    Feb 2017
    El Paso, TX
    42
    Yellow Stain in Spa
    Last night I noticed I had a yellow stain in my spa (which is attached to my poo) that wouldn't brush off. After doing some research, I placed a chlorine tab directly onto the stain and the stain lightened up.
    Today, when I checked the stain was gone on that spot but a new spot appeared ( see attached picture).
    The pool water looks great and the numbers are as followed:
    Test from today:
    FC: 6
    CC: 0
    pH: 7.8
    TA: 80
    CYA: 40
    CH: 320
    As you tell from the picture, I went ahead and drained the spa. Is the stain algae? And how should I get rid of it and prevent it from coming back?
    Thanks for the advice.
    Plaster, 2 HP WhisperFlo Pump, DE Filter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Yellow Stain in Spa
    If the puck cleared up the stain then it is organic. More here, Pool School - Pool Stains
    You can do an Overnight Chlorine Loss Test to see if you have some algae growing. If so, then SLAM to kill the algae.
