Results 1 to 7 of 7
Thread: converting to liquid chlorine/ how much will I use
    Apr 2017
    houston,tx
    2
    We had a salt pool and converted it to chlorine due to constant corrosion issues. We live in Houston Tx, and as I do more research I see that the use of liquid chlorine is superior in order to avoid elevated CYA issues and everything associated with it. All this being said, we have a 16k gallon pool/spa. with Ideal CYA at 30-50ppm how much and how often should I expect to add the liquid chlorine. to keep the pool at 2-3 ppm FC in the heat of the summer?
    Aug 2016
    Pittsburgh PA
    345
    Re: converting to liquid chlorine/ how much will I use
    Can you elaborate on the corrosive issues you experienced with salt? Did you always maintain proper PH?
    Just curious as I'm putting in a salt pool.
    18'x36' vinyl - 24k gal - Intelliflo 3hp VSP - Pentair C&C 420 cartridge filter - IC40 Salt - EasyTouch 8 - ScreenLogic - Raypak 406btu NG heater - Intellibrite 5G ligths - 4 deck jets - sheer descent - X-Stream Slide 2 - TF100 kit - opened spring 2017
    Apr 2017
    houston,tx
    2
    corrosive meaning we replaced a heater, three pool pump motors, one waterfall pump motor and pool cleaner pump all within 10 years. previous pool we had was chlorine and we had it for ten years and never once replaced a single thing. Oh also both our pool lights are corroded as well. As far as maintaining perfect ph at all times , probably not always but compared to similar handling of pool chemistry in our chlorine pool it was terrible to have the salt.
    Dec 2015
    Mesa AZ
    8
    The SWCG puts upward pressure on the pH in a salt pool. If this is not monitored and adjusted with MA, most salt pools will become corrosive. However, most salt pool owners dump in a lot less acid into their pools then chlorine pool owners dump bleach/chlorine in.
    Do you own either the TF-100 or Taylor 2006 test kits?
    Mar 2017
    Fort Worth, Texas
    137
    You seem to have already made your decision on this, so I will advise https://www.troublefreepool.com/calc.html for your initial dose. You need to use a reliable test kit which can be found here Test Kits. By putting your levels in the left column and the target in the right hand column as well as your pools information it will tell you the initial doses. After that the frequency will be based upon your pool and you're testing will let you know how much to add. Everyone's Chlorine consumption is different, so accurate, consistent testing and using the link above will serve you well.
    22X40 31000 gallon IG. AquaBright plaster, Jandy 2hp epump, 60sqf de filter, Aquapure 1400 SWG, Polaris 965, jxi400 propane heater, iaqualink control, 2 Watercolor LED lights, Taylor K2006, My Build Thread
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    Quote Originally Posted by bonniecypher View Post
    Hello, welcome to TFP!
    To answer your liquid chlorine question, most see around 2-3 ppm loss, maybe a little more in your area and depending on CYA level. on a 16k gallon pool, this is about 70oz (1/2 jug) per day. At first you will want to test and dose daily, usually in the evening. Then as you learn the pool, you can test less, but still dose daily. You can use normal, every day bleach from the grocery store. Where ever you can find it the cheapest and fresh.
    Now, I'm going to point you to Pool School. Please read up on the Getting Started section. They will help answer a lot of questions you may have.
    Also, your FC level will depend on your CYA level. There is a Chlorine / CYA Chart that you can use as a reference.
    As for your maintenance troubles, I don't think that salt was the main culprit unless the salt waster was splashing directly on them over their life. Did the heater fail from the inside or the outside? Even a liquid chlorine pool can have a surprising amount of salt in it. Each time you dose with liquid chlorine / bleach you are adding salt. But, liquid chlorine or a SWG are much better method than solid chlorine. Proper testing and water adjustments are key to making the equipment last as long as possible.
    Nov 2015
    Carrollton tx
    487
    As was stated before the corrosion wasnt likely JUST the salt.
    You admitted not keeping close track of the PH.
    With a liquid chlorine pool you will need to keep even closer track of chlorine. Meaning adjusting every few days at least..
    Are you sure thats what you want ?
    Are you sure you kept the salt level at the correct PPM ? "Under normal salt levels however, the amount of corrosion caused by pool salt is negligible."
    There are dozens if hot hundreds of people here with salt pools that didnt have the same issues ..
    Doug - Purchased 1/2016, 1995 house with 16x31 ft, ~23000 gallon Gunite pool w 11x7 spa, 3 Pentair VS pumps, a boost pump for polaris 3900 and a BaduŽ Jet super-sport swim jet pump, 1.5 hp blower, a CL460 Cartridge filter. TF-100 test kit. Aquapure 1400 SWG, iAqualink - Lots to learn. New Aquabright, Jandy LEDs, CMP LED Sheers.
