Thread: How long do I have to test after sample?
    Jan 2014
    Brookhaven, MS
    45
    I cant be at home during the day to test my CYA where the sun is at my back.
    Can I take a sample before leaving work and test it a few hours later when the sun is out?
    Does a sample skew the test results if waiting too long?
    18x36 25k Gal Inground Vinyl Pool
    300lb Sand Filter / 1.5hp Single Speed Pump / Intellichlor IC40 SWG / Polaris 280 w/booster pump
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Re: How long do I have to test after sample?
    I think what messes the test up is, the water being too cold. I have been told to bring inside the house to warm up, then test. So I guess this would make waiting a little while just fine.
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    May 2011
    lebanon tn
    370
    Just keep it sealed in a closed container. A couple hours shouldn't affect the test
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Jan 2014
    Brookhaven, MS
    45
    Thanks guys - that helps. I was testing my CYA after hours and in less-than-ideal lighting.
