Thread: Opening questions
    Jun 2016
    Manteo north carolina
    51
    Opening questions
    I am getting ready to open my pool. Starting the slam process. What should I have my cya at when starting a slam? Do I need to work on ph and alkalinity before I start or is that something I can do while slamming. Do I need to add salt? Thanks for the help
    Above ground intex 24x 52 Swg with sand filter pump. Well water. New started the end of May. 11,600 gallons. Test kit TF100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Opening questions
    All of those great questions and more are answered right here in this link, SLAM.
    Jul 2016
    Mebane/NC
    23
    CYA needs to be between 30-50 for outdoor pools.
    Here's some resources:
    https://www.troublefreepool.com/calc.html (Great resource to keep everything in check).
    Pool School - Chlorine / CYA Chart
    Pool School - SLAM - Shock Level And Maintain
    Hope these help.
    32 X16 Vinyl 20,000 gallon in-ground, Hayward S244T2 Sand Filter, Ecotech EZ Variable Speed 1.5 hp pump motor. TF-100 test kit.
    https://www.mebanepressurewashing.com
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    No, you don't need to add salt, because we suggest not using the SWG during a slam. Yes, adjust the pH down to 7.2 before you start. Follow the procedure, but ask us questions if they arise. Someone will be here to help.
    Essential Links:
