Thread: Pressure gauge stuck at 10
    Jan 2016
    Wichita, Kansas
    94
    I think I already know the answer, but my pressure gauge doesn't go down to zero when the pump is off. Doesn't change when tap it either. It does go up to 18 when I turn it on which seems high. Am I correct to assume it needs to be replaced?
    AG Doughboy 16x28', Opened June 2016
    Aquaview 20" filter w 7 position valve
    1-1/2 hp Powerline Pump
    TF-100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Pressure gauge stuck at 10
    Yes, it's dead. TFTestkits.net sells a nice, oil-filled gauge for pretty cheap.
    Jan 2016
    Wichita, Kansas
    94
    Thank you, hopefully that one will last longer, just used the one year.
    TF-100 Test Kit
