Results 1 to 8 of 8
Thread: CYA is there a way to lower without draining?
    Mar 2017
    SE. TX
    52
    We have finally finished the SLAMing and now I am trying to get all the numbers right.
    Right now
    FC 6.5
    CC 0
    CYA 55
    TA is 130
    PH is 7.7
    I thought I would tackle the CYA problem first and try to lower it the recommended amount. I would love not to have drain it again, is there a way to lower it since it is only a little bit out of whack?
    Then if I lower the PH to 7.0 that should lower my TA right?
    I have a 24ft round pool. 52in deep. 14k gallons. It has a sand filter. It is a chlorine pool that we got March, 2016. Above ground!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: CYA is there a way to lower without draining?
    The only way is to replace some water, but honestly I would not lower it much. Summer is coming on, and most of us in the Southern US find that 40-50, sometimes even 60 is a great place to be. This is most true if you get full sun on the pool all day long.
    Yes, repeated lowering of your pH will bring the TA down, but it will take a little while. Longer or shorter depending on your fill water TA, and the amount of water you replace.
    Essential Links:
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    I wouldn't worry about that CYA number vs. your FC reading. Watch it for awhile and see how it does over time. As long as you keep your FC number in range you're fine.
    12,000 Gal, InGround, Spa Attached, Satin-Matrix Northshore Tahoe Pebble-Tec, Remodel 6/15, Taylor K-2006 Kit, Pentair IntelliFlo Variable Speed Pump, Polaris 280 Sweep, Jandy CL460 Cartridge Filter, Solar Heated. Taylor K-2006 Test Kit
    30,964
    For that soon to be, hot Texas Sun, your numbers are just fine. Go swimming!
    Mar 2017
    SE. TX
    52
    Thank y'all so much!
    Mar 2017
    California
    10
    I think there's a way. I heard about a pool water recycling service in Vista that uses reverse osmosis technology to lower CYA.
    You may want to try and search something like "Pool Services Technologies" in Google to bring up their website.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Let it alone-raising mine to 50 or so tomorrow!
    Frankhugus's Avatar
    Feb 2016
    Danville, CA
    190
    Watchful waiting.
