I'm asking the sub on my O/B to beef up the rebar on my pool. Standard is #3 @12". For about $500 I can get #3 12X6 vertical & 6X6 on the floor.
I asked for 4000psi for the shotcrete, instead of the standard 3000psi the sub quoted me.
I'm in an area of AZ that can have expansive soil, so I want to take extra precautions.
I have one sub who said no problem, and the other replied with this:
3000 psi is the standard for swimming pools. We can use 4000 psi for an additional $200 but he doesn't recommend it. He said you will have a stronger, more durable pool using 3000 psi.
At 4000 psi, the concrete sets up faster and is already getting hot while the crew is still doing the finish work. It clogs the hoses slowing down the process and causing breaks in the material.
The shotcrete design that we use, while being guaranteed to 3000 psi consistently tests higher.
Does this answer make sense?? Obviously, I want the strongest shell. My build will start early May.
I appreciate any feedback!
Thanks
Thanks
