Thread: 1 Spa Jet Not Working
    Mar 2015
    Largo, FL
    94
    I have 4 return jets in my built-in spa. When I set the return to spa-only mode, 3 of the jets shoot water really hard and aerate properly. The 4th jet just barely has a small trickle of water drip out of it. As far as I can tell, there is no noticeable water loss, so I doubt it's a leak. Perhaps a clog? What is the best way to go about troubleshooting this problem?
    15k gallon (?) kidney-shaped inground concrete (paint) pool & spa combo undergoing resurfacing. 6 floor jets, 2 side returns around steps, 1 skimmer also near steps. Spa has 4 jets. 1 hp Sta-Rite Supermax, 1.5 piping, Pentair CC100 cartridge filter (holds up to CC200), ComfortZone gas heater - old and broken, Master Pool return distributor (not sure what to call it). Pool Before Resurface
    mas985's Avatar
    Pleasanton, CA
    11,983
    Re: 1 Spa Jet Not Working
    Remove the exterior fitting and also the interior jet nozzle and then flush the line. Have you ever removed a jet nozzle before?
    Mark
    Mar 2015
    Largo, FL
    94
    Quote Originally Posted by mas985 View Post
    I've removed what I think you're calling the exterior fitting and put it back on before. I don't believe I have spa jet nozzles. I just have spa returns that are very similar to pool returns, like this one.
    As dumb as this sounds, how do I flush the line? (obviously, I've never done that before)
    mas985's Avatar
    Pleasanton, CA
    11,983
    If you drain the spa, remove the exterior fittings, and look into the jet hole, you will see a fitting deep inside that can be removed with a long socket wrench. It usually looks like this:
    Mark
