Thread: To slam or not to slam?
    Johnmarkpainter's Avatar
    Apr 2016
    Hendersonville, TN
    55
    Forgive me...I neglected my pool.
    Leaves built up and stayed in for a while (kids broke the leaf rake!) and I wasn't checking my FC. I didn't winterize.
    OK...I am cleaning it up and it has eaten some chlorine. Leaves are out, I am brushing, vacuuming, backwashing and testing. Water is fairly clear until I brush up the dirt. CL dropped twice after adding bleach. I can see that the dirt is turning gray/white as opposed to brown/green.
    Salt 2600, FC 5.5, CC 0, PH 7.5, CYA 70, Temp is around 70F. I use Borates.
    I am going to test again this evening. At what point do I know I should SLAM? Does it ever just stabilize after a few cycles of adding bleach like I am now? I added 256oz of Aldi bleach yesterday.
    THANKS
    I promise I'll do better next winter
    28,000 Gallon, IG, Vinyl, SWG, Sand Filter
    Goldline Aqua Rite SWG
    Hayward Pro Series Sand Filter
    Flotec Pump
    Hayward Turbulent Flo Chamber
    Jun 2014
    17,343
    Re: To slam or not to slam?
    I think you already answered your own question ... SLAM! Follow the instructions on the SLAM page (link below) and don't let-up until you pass ALL 3 SLAM criteria to pass. Reminders:
    - Lower pH to 7.2 first
    - Based on your CYA (70), increase FC to SLAM/shock level of "28". Keep it there until you pass.
    Good luck!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Pat, I dont know if that's a new meme or not, but I give it the HANDS DOWN best meme ever on TFP.
    X 100.
    No worries Johnmark, you're on the right trail, and you've got me laughing too. Sorry about your pool, but love your sense of humor.
    Essential Links:
    domct203's Avatar
    Jun 2015
    CT
    3,912
    Quote Originally Posted by Johnmarkpainter View Post
    THANKS
    The line I highlighted above in your post is your first clue. "Dirt" doesn't really bleach out, but algae will lose it's color when it dies. What you are seeing is dead algae.
    Whenever the water looks "off", cloudy, or just "not right" as well as if your FC goes to 0 or a noticable increase in your daily chlorine demand is a sign that you should SLAM. If that is still uncertain for you, perform the OCLT and if it fails it is definitely time to SLAM.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    30,961
    Dom's observation is spot on the money. That's dead algae.
    I have a couple of observations.. Please read "The "ABC's of Pool Water Chemistry" up in Pool School. You don't yet have a good idea of the SLAM process, either so also please read the SLAM article in Pool School.
    Without pretty careful testing and dosing, your SLAM will be a failure.
    Apr 2016
    Hendersonville, TN
    55
    Thanks!
    I do understand the process. I had doubts because I was quickly seeing the water improve with just getting the FC up to normal and I had zero CC. I turned off my SWG and if I don't go ahead and SLAM today, I'll do the OCLT tonight. We are getting a lot of rain today and tomorrow though so I'll likely just go ahead and SLAM.
    Aldi here I come...
    Flotec Pump
