Results 1 to 9 of 9
Thread: Vacation Pool Care
    Jun 2012
    Austin, TX
    97
    Vacation Pool Care
    I am about to go on vacation for the first time since our pool was built in October (we'll be gone 8 days). I am concerned about rising pH levels while I am gone, but I hate to let a pool company get anywhere near my perfect pool. I am adding acid about every 3rd day and I'm worried about what will happen if it gets too high for several days while I am gone. My most recent pH results are below - if anyone has any advice or can ease my mind about the pool having a high pH for 3 or 4 days I would really appreciate it.
    Friday: 7.8 (added acid)
    Sunday: 7.8 (added acid)
    Monday: 7.5
    Tuesday: 7.8
    Wednesday: 8.2 (added acid)
    32x15 freeform gunite pool (approx 15,000 gallons) with a 7x7 raised spa with 2 spillovers - tanning ledge with 2 bubblers - All Hayward Equipment - ARQ15 SWCG - 400btu heater, 60sq ft DE filter - 2HP EcoStar VS pump - Oklahoma flagstone coping - MasterTile MASMIX 3 1x1 - Sundek - Crystal Stones Smooth Caribbean Blue - TF-100 - Doheny's Discovery Robot
    May 2016
    West Bloomfield, MI
    757
    Re: Vacation Pool Care
    My plaster is about the same age as yours. My pH became relatively stabile about 2 months ago... I wonder if you're seeing rise not because of new plaster but because of the spillovers and bubblers? I can definitely go 8 days without pH spiking.
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    30,955
    Can you post all your test results to get us a better picture of your pool? TA and CH in particular but all of them would help.
    Jun 2012
    Austin, TX
    97
    Chlorine: fluctuates between 5 and 6
    TA: 70
    CH: 325 (my pool builder told me not to increase this because it would go up over time - it started at 200 and has gone up to 300 since the pool was built)
    CYA: 50
    Salt 3500
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    This is a perfect time for trichlor tabs in a floater. Your CYA needs to come up anyway and the tabs are acidic.
    Turn off any spillovers and bubblers as well, as Rollercoastr mentioned.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jun 2012
    Austin, TX
    97
    If I put the floater in, how much should I turn down my SWCG? I don't want it over-chlorinated.
    I read somewhere that you should turn off the skimmer when you go on vacation. Is that a good idea?
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    3 tabs in a floater will raise FC by ~4.5. You won't get close to SLAM value for a CYA of 50.
    If there is any chance the skimmer would get clogged (leaves, etc) it's better to not chance it. Some people have gotten creative with milk crates hanging in front of them to prevent such a thing.
    If I am away from my pool for any length of time I leave the solar cover on. 1) Keeps FC consumption down 2) Not really skimming the surface so much less likely to get so many leaves that it clogs.
    30,955
    The tabs are certainly a viable approach. I also would consider lowering the pH to around 7.2 just before I left and let the SWCG run. It may be a little high by the time you get back but it will not have been high enough, long enough to do any damage.
    EDIT:
    I should have clarified...."it" is pH
    Mar 2016
    Spring, Texas
    50
    How much do you drop your PH each time normally? Have you ever tried taking a bigger swing? My pool is 5 months older, and I am just down the road, but I have similiar PH rise. Though this spring I've actually been able to go almost a week without having to add acid! Yea! I suspect, but haven't proven that the spa spill overs (I have 3 that spill ~1 ft anytime the filter is running) are probably a big contributor. I've been debating turning them off as an experiment for a while now. But they are also a quick and easy visual first clue as to how my filter is doing any given day (even a 5-10% rise in filter pressure or drop in flow significantly effects how much spillover I get) and I like the sound. Ironically I also have a wall with 3 more waterfalls but I only ever turn them on when we actually in it.
    21000 gal IG Pebble Sheen (Blue Surf), Pentair quad DE filter, Sta Rite Intellipro VS pump; Paramount PCC-2000 inground cleaner; Installed May 2016.
