Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Opinions on Heater Estimate
    May 2013
    Las Vegas, NV
    9
    I'm just looking for a recommendation based on my choices from the estimate below. Unfortunately, a Raypak doesn't seem to be a good fit for my setup. Any advice on which to choose or avoid would be appreciated.
    Phil (Las Vegas)
    Built 2003 - 12,000 Gallon In-Ground + 620 Gallon Spa ~ Pebble-Tec ~ Sta-Rite System 3 Cartridge Filter ~ Sta-Rite Natural Gas Heater ~ Solar Heating ~ Pentair Intelliflo Variable Speed Pump (2015 Install) ~ Pentair Intellichlor SWG (Not used since 2013) ~ Sun Touch Control System.
    JoyfulNoise's Avatar
    May 2015
    14,083
    Re: Opinions on Heater Estimate
    I would get a few more quotes from other contractors.
    There is literally no difference between the Jandy or Pentair units that could justify a $300 increase in price other than this particular contractor wants you to go with the Pentair system and clearly does not want to sell or install a Raypak. Raypak's are a little bit different than the other models, but I really don't buy their justification that there is something about the clearances that means they absolutely can't setup a Raypak. The quote looks fishy to me but, if you want an opinion on what's there, either the Jandy or the Pentair will do the same job so you might as well go with the Pentair since you have all Pentair equipment as it is.
    Matt
    ps0303's Avatar
    Jul 2011
    FL
    3,920
    So the contractor says there is no way to get the Raypak in? I take it that since the Raypak foot print is larger you have to move it some on a new pad and that puts it too close to a window/door?
    Get at least two more bids/options.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Aug 2016
    Riverside, CA
    378
    The contractor should be listing the exact model numbers in the bid and I would want it itemized so I can see how much each component is such as the heater itself, new piping and labor. The gas line is flex as is the power whip so that shouldn't need to be in the quote at all as these can be re-used. If they show up in the quote it is an area to get some concessions. Make sure you get the heater you are paying for and verify the cost of the heater versus what you can procure it for yourself is not out of line or it is merely padding the labor cost.
    Jan 2017
    Orlando/FL
    124
    Looking at prices for these units at InyoPool.com the Jandy is about $250 more than the Pentair. But based on the prices your were quoted, your paying about $850-900 in labor.
    The physical size of the heaters is about the same. I just replaced a Jandy (old millivolt) with the RayPak 406. Size wise not much difference.
    You didn't say what model StaRite you have now - but you may want to also consider how the plumbing to the current heater is setup now and how the new heater's plumbing is laid out.
    Some (Master Temp) have the inlet and outlet fittings above/below each other, others (Raypak, StaRite Max-E-Therm, and older Jandy) have the inlet and outlets side-by-side. If you buy a new heater and the connections are in the same place it invloves a lot less labor to hook it up.
    Are you also considering the StaRite Max-E-Term? it is the same price range (and has that plastic "no rust" housing which is a plus).
    Lastly, why should the RayPak be not considered? What is this about the location to gas and window? All of the heater need to be a minimum distance from house, windows, overhangs, etc. The RayPak has no limitations that are worse than the others. On the RayPak (was same for my older Jandy) you can reverse the heat exchanger manifolds so the inlet/outlet can be on either side of the unit. I did this on my RayPak so the gas line and the plumbing were both on the same side. I think all of the heaters can have the plumbing inlet/outlets swapped around.
    20K gal In-ground pool with raised Spa overflowing into pool; two Jandy Sheer Descent waterfalls; Pentair IntelliTouch i7+3, IntelliChlor, IntelliPH, 3 SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, RayPak 406A LP spa heater, Polaris 360 PS Cleaner. Patio and deck lighting by Volt; Volt 600W landscaping transformer; Webber grilling station
    May 2013
    Las Vegas, NV
    9
    Wow - thanks for all the great information. I will definitely act on it. As for the Raypak, the explanation was that it would wind up under our bathroom window and therefore it wasn't a recommended option.
    Here's a couple of shots of our setup:
    Phil (Las Vegas)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Perhaps put it on the other side of the window. Maybe not the most pleasant idea, but a next best thing?
    Essential Links:
    Jan 2017
    Orlando/FL
    124
    I would consider using the Sta-Rite heater. Since that is what you have now, it may be the easiest to swap out (assuming the size and plumbing connections are the same location). If that is the case then you should be able to knock off $500 on the installation cost. Sta-Rite Max-E-Therm Heater 400000 BTU NG Ele. Ign. - SR400NA - INYOPools.com
    ps0303's Avatar
    Jul 2011
    FL
    3,920
    Quote Originally Posted by CountryBumkin View Post
    $500 bucks??? That's crazy. That quoted price to replace it with another Sta Rite is the going price in that area and even in Tampa. MAYBE ask for $100 off and see but not $500.
    Paul
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Yikes!
    I dont know I'd be bold and brash enough to ask for $500 off of any service like that.
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Multiple quotes always keeps folks honest.
    Jan 2017
    Orlando/FL
    124
    Quote Originally Posted by Patrick_B View Post
    Yikes!
    Only that OP is being (over) charged $850-$900 for labor based on prices of the heater's listed at InyoPools.com so if it is just a matter of removing old StaRite heater and installing a new StaRite heater with no plumbing or gas line rework needed, then cutting the installation cost to $450-$500 would be fair (even though still priced too high IMO).
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    A local expert on the area that says it's the going price is what I see.
    Essential Links:
    Aug 2016
    Riverside, CA
    378
    Shouldn't be more than $250 to put that heater in.. Max 2 hours plus parts.
    ps0303's Avatar
    Jul 2011
    FL
    3,920
    The OP can do as they wish. I'm just saying that from a person that this is all I do, the price is right. When you get the $250 guy, he is not licensed or insured. This is what I see all day long. In Florida you are supposed to be a licensed pool contractor and have a valid gas license even if you are just swapping out units.
    Just get three bids from licensed companies and go from there. If all three companies are within the same price range then you can be assured the price is the price. If one is say $400 or so less, ask why they are so much less than the other quotes. Can you buy cheaper on the internet, sure. But if that unit comes damaged or doesn't work correctly out of the box, who are you going to blame? Been there seen that. In my business, if I sell you a unit and there is damage to it or if it is broken right out of the box, yes it happens, I can take it back to my supplier right then and there and bring you a new unit the same day. No calling around trying to explain what is wrong with it, waiting for a new shipment to arrive and sending the old one back.
    Just some food for thought.
    Paul
    Aug 2016
    Riverside, CA
    378
    The licensed contractor that just installed my pump charged $220 plus parts and it is very similar work except it is hooking up 220v instead of NG. In CA a pool contractor licence covers all trades required to do work associated with pools, AFAIK. This is not rocket science. I'd do it myself except for not wamting to do it myself..
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Paul is a loyal member of the forum and offers a lot of helpful information on a VOLUNTEER basis. Posts are leaning toward accusations of unethical pricing. If he says that's the going rate in a part of FL, it's good enough for me. If the OP gets something he likes better then so be it. We have all had enough to say about that, so let's drop it, and give the thread back to the OP on solving his issues.
    Essential Links:
    Aug 2016
    Riverside, CA
    378
    Sorry if I may have offened anyone.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,607
    My heater was just replaced too, swap out with a Raypak.
    It was $ 2,900.
    The estimates op got don't look bad at all to me and
    he's getting a much bigger heater than I got.
    Dolphin E10 Cleaning Robot.
  20. Back To Top    #20
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    No problem Sammy, it's all good! Thank you.
    Essential Links:
