Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: When to Clean a DE Filter?
    Aug 2016
    Riverside, CA
    378
    Is this on a set schedule or based on changes in pressure on the tank pressure gauge?
    (I'm leaning towards the latter)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Re: When to Clean a DE Filter?
    Pressure increase.
    Check out DE Filter Cleaning Tutorial
    40,855
    Clean when pressure rises 20-25% over the clean pressure. That is true for all filter types.
    Jul 2012
    Dallas, TX
    179
    Sammy2
    I do the same as your leaning; I use my PSI Gauge as well as my Flow Meter to determine my Backwashing as well as the necessity to pull the DE Grid Assembly for a complete cleanup.
    Here's a couple of threads where I provided my information regarding the frequency of Backwashing & Filter cleaning.
    Backwashing
    is there a consensus?
    Since switching to TFP methodology (Bleach dosing / CYA ratio), my Backwashing frequency has dropped from using the old rule of thumb pool store once-a-month, to averaging ~3-5 months.
    The last time I pulled my DE Grid Assembly (cleanup) was Sept 2013. With my pool's DE Filtering tracking, I have seen no indication of a requirement to pull the Filter more frequently or Backwashing at 25% increase although I'm aware that is the forum recommendation method and am not disputing that stance.
    Perhaps my pool is an anomaly regarding DE filter characteristics (Backwashing / cleaning frequencies), or perhaps the pool isn't exposed to as much organics / pollen, etc as the majority of pools. I do have an overhanging Pecan Tree that seasonally drops pollen, leaves, blooms into the pool.
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,259
    Scoop,
    Our backwashing rule is designed to cover all types of pools and filters and because of this is on the conservative side. It is not a do this, or your pool will go up in smoke type of rule.
    If you have found something that works well for you, then you should keep using it. Our goal is to provide guidelines that help owners maintain their pools with the least amount of issues.
    Thanks for posting,
    Jul 2012
    Dallas, TX
    179
    It wasn't my intention to imply a 'going up in smoke' scenario if someone's DE cleaning experiences appears to run contrary to the established forum advice as I said "I don't dispute the forum recommendation."
    Jul 2014
    Bedford, TX
    9,259
    Scoop,
    Sorry, I think you took what was supposed to be a joke the wrong way... I thought your post was great and was just trying to agree with you.
    No offence intended..
    Jul 2012
    Dallas, TX
    179
    Jim,
    I think I owe the apology here, as I assumed the wrong way.
    The topic is diverse, pov's appear to be somewhat opposite on DE Backwashing/cleaning frequencies. As you said, the pool owner's decision is the determining factor.
    One thing's certain in my pool's case; since switching to TFP dosing / CYA ratio, my pool's filter maint & overall water condition have been amazingly free of issues.
    Aug 2016
    Riverside, CA
    378
    Group Hug
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Quote Originally Posted by Sammy2 View Post
    Group Hug
    Sent from my SM-G930P using Tapatalk
    Essential Links:
    JoyfulNoise's Avatar
    May 2015
    14,083
    The forum recommendation of a 25% change in pressure is just that, a recommendation. In my own pool, if I waited for a 25% increase it would take over a year for that to happen since my DE filter is very much oversized in relation to the pool volume being filtered. I have literally gone one full year without cleaning my filter or backwashing and the filter pressure has not changed more than 25%. My normal mode of operation is to tear down and clean the filter twice per year (I do not backwash). Doing so keeps the Quad cartridges clean and I use precisely one 10lb bag of DE with each cleaning. If I back washed as the pool store recommends, then my DE costs would be a lot higher and my filter quad cartridges would be under more frequent stress. Remember that for a DE filter (grid or cartridge style), backwashing is not the normal flow pattern and puts a lot of stress on the filter medium. This reduces the life of the grids or the cartridges are is most often responsible for torn fabric or blown out cartridges.
    Matt
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Great points. Lots of pools out there, and no two are exactly alike.
    Essential Links:
    Aug 2016
    Riverside, CA
    378
    So I won't/don't need to backflush the filter. I need to check but my filter is quite large, maybe oversized even. I'd love to be able to go a year without cleaning it. My pool doesn't get many leaves at all in it as there's not a whole lot of trees around. We get cottonwood "cotton" in the spring and an occasional piece of debris on the bottom or floating on top but not a whole lot actually. I am thinking that my pool guy was cleaning the filter too often at $70 a pop so I will be monitoring this. He just did it last week, or so he said, so I will make note of the pressure on the gauge tonight and call that my baseline for this run.
    Aug 2016
    Riverside, CA
    378
    BTW, what's the range that the gauge should be in out to 3 standard deviations of the mean.
    Aug 2016
    Riverside, CA
    378
    Currently mine is at 14~16 psi running at 2200 RPM if that matters.
    So I should get prepared to clean it when it hits 17 psi and clean it before it hits 20 psi?
    Aug 2016
    Riverside, CA
    378
    BTW, my filter is a Pentair WMBW 2060, with 58SF filter area. Is it big enough for my pool, which is probably a little less than 16k gallons.
    40,855
    Plenty big. Mine is 60sqft for a 18k pool.
    Aug 2016
    Riverside, CA
    378
    22 psi @ 3450 RPM so start getting ready to clean it @ 26 psi and clean it @ 28 psi?
    40,855
    Pretty much. Just clean it when you hit about 27psi.
  20. Back To Top    #20
    Aug 2016
    Riverside, CA
    378
    By "start to get ready" I mean, "procure 6 lbs DE."
