Thread: how much mortar sealant tubes did you use when replacing ?
    Apr 2017
    Atlanta, GA
    1
    I have a 40000 gallon pool and its free form so I don't know the square footage, but approximately how many tubes of sealant are needed to replace the mortar between the flagstone and pool? like Vulkem45 SSL? or something similar. thank you!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: how much mortar sealant tubes did you use when replacing ?
    No Idea, But wanted to say Welcome to the forum.
    Perhaps the bump will get you some help.
    Essential Links:
    Jan 2017
    Orlando/FL
    124
    No one can you how much sealant you will use - since no one can see how many feet your trying to work with.
    Go to the product's manufacturer website and use their calculator to get any idea of how many tubes you'll need Technical Resources: Sealant Calculator
    20K gal In-ground pool with raised Spa overflowing into pool; two Jandy Sheer Descent waterfalls; Pentair IntelliTouch i7+3, IntelliChlor, IntelliPH, 3 SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, RayPak 406A LP spa heater, Polaris 360 PS Cleaner. Patio and deck lighting by Volt; Volt 600W landscaping transformer; Webber grilling station
