Thread: Decided to convert to SWG
    YetiAsr's Avatar
    Dec 2016
    Pflugerville,Tx
    70
    And have a question regarding automation. I currently have Hayward Ecommand control panel and purchased the Hayward AQ15 SWG, would I use the Ecommand to control the SWG or the control panel that came with the SWG? After reading the manual they make it sound like you use the Ecommand but it seems easier to use the Aqua Rite , any help would be appreciated , thanks
    31x22 FF IG, 16k gallon , 3.5-5.5-4.5, Hayward 425 cartridge, Tristar variable speed, Aqua Rite AQ15 SWG, HPC 4 wireless controller, LED, Texas Grey pebble finish, Taylor K 2006 and 1766,speedstir ,New build in central Texas....
    YetiAsr's Avatar
    Dec 2016
    Pflugerville,Tx
    70
    Re: Decided to convert to SWG
    After researching a bit more I think I'll just use my current automation for controlling the SWG. I do have another question though, should I start adjusting chemicals to SWG levels now or wait till after the system is up and running?
    Current levels:
    FC 6
    CC 0
    PH 7.7
    TA 80
    CH 300
    CYA 40
    Borates 50
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Now is fine. You want to give the salt 24-48 hours to dissolve and mix, or longer if the pump isn't on 24x7.
    Have you seen this handy page?
    Pool School - Water Balance for SWGs
    YetiAsr's Avatar
    Dec 2016
    Pflugerville,Tx
    70
    Yes I have DV, read it many many times, thanks for the info
    Btw I currently run my pump 7 hrs at 60% but plan on experimenting with times and output depending on chlorine output.
