Thread: Leak somewhere?
    Jul 2015
    panama city, fl
    1
    Leak somewhere?
    Pool was full. Left town for a few weeks. Water had dropped about 28 inches. The only thing i had done different was I had left the jets on the cozy cove open the last time I had the grandkids in the pool. Noticed the jets would just spin and not close anymore. (just floppy) Can this cause such a drastic leak? Haven't been able to find a leak anywhere else! Is there a way to seal off these jets or a few of them?(there are 6)
    anyone have a clue? Please help! Had this same pool in Indiana but had steps, instead of cozy cove swimout with jets and never had a problem.
    2006 ,18x36 ig vinyl pool, cozy cove swim out w 6jets, Haywood sand filter, 2 returns, skimmer, 3.5' to 6' deep
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Leak somewhere?
    Hello, and Welcome!
    Sorry you haven't been answered, but hoping a bump to the top will get you some help. Good luck, amd enjoy the forum!
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Leak somewhere?
    Welcome to TFP!
    Did the water leak down to the depth of the jets? That is usually the easiest way to track down a leak, if the leak stops at a light or a jet,etc that indicates where the leak is. It is probably easiest to have a pool company remove and reseal the jet rather than sealing of the plumbing line.
    More here about tracking down leaks, Pool School - Leak Detection
