Page 1 of 2 12 LastLast
Results 1 to 20 of 37
Thread: Newbie wanting to add thru-wall skimmer...
    Apr 2017
    Hamilton, IL
    17
    Hey, everyone! I have the Intex Ultra Frame pool 16'x48" model with the all-in-one Intex sand filter and salt water system and wanting to do the Hayward skimmer solution that a lot of people on here do. I was curious what to do with the current underwater skim port? I see some keep it and some don't. The only reason I can see keeping it is because I have the Intex vacuum kit that attaches to it with the adapter. If the Hayward one will fit it then I feel like I don't need it tied into the pump.
    I've also seen where some have tied both the Intex ports as inlets from the pump to push water back in the pool and only use the skimmer as the return. Just looking to do this the right way! Thanks all.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Newbie wanting to add thru-wall skimmer...
    Hey,
    Welcome to TFP!
    Others that have done it can help you better than I. Good luck on your upgrade, and enjoy the forum.
    Essential Links:
    chayne's Avatar
    May 2016
    Somewhere Around The Red River, Texas
    419
    i dont have an Intex but i do have a Coleman pool. what i did with the extra intake port was to cut the opening a little bigger and added this part
    https://www.amazon.com/dp/B003ZTM0O2...=IVQVSJ9EWHOZ1
    then i put the cover from the orginal intake over that and ran it over to my solar heater behind the fence.
    you could also add that same fitting to the pool and then put this plug over it
    https://www.amazon.com/dp/B0055EHLKS...I2LN0IM12YNPLZ
    here is what my set up looks like. i did install the widemouth skimmer on mine.
    Charles
    Coleman 16'x48"
    Intex 16" pump & Sand filter, Intex Robot Vacuum
    Hayward Wide Mouth Skimmer
    TF-100 Test Kit Magnetic Speed Stirer
    Apr 2017
    Hamilton, IL
    17
    Thanks for the replies! I found another post showing where they tied the two intex inlet ports together to help with circulation of water and only used the Hayward skimmer outlet to pump. I think I may go that route (unless you see a dire reason this is a bad idea). Can anyone verify if I can use my intex vacuum kit with the hayward skimmer?
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    1). I wish I had kept my original port just to be able to filter water from below the surface in addition to on top. I would have installed a valve so that I could regulate between surface, submerged, or both. Once debris has sunk beneath the surface, the only way to get it out is with a vacuum without an intake below the surface.
    2). My Hayward Dynaskim came with a vacuum attachment plate. It doesn't fit the Intex hoses, but it fits the generic vacuum hoses available at any store that sells pool accessories, ie. WalMart, Home Depot, Lowes.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Apr 2017
    Hamilton, IL
    17
    Quote Originally Posted by jeffchap View Post
    Are you saying a setup like this would be preferred? (found image using google)
    jmcdtucson's Avatar
    Jun 2014
    332
    Quote Originally Posted by mwc104 View Post
    Yes, that's my setup exactly. The second port protects you in case the water level gets below the skimmer or skimmer gets clogged, then the pump won't be sucking air - it will get enough water thru the old port to keep it functioning.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    That's how I would do it.
    Pentair IC40 SWG
    Apr 2017
    Hamilton, IL
    17
    Quote Originally Posted by jmcdtucson View Post
    Didn't even think about the water level lowering and pulling in air! Excellent point! See, told you guys I'm a newbie
    jmcdtucson's Avatar
    Jun 2014
    332
    I didn't either, until it happened to me...
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Apr 2017
    Hamilton, IL
    17
    Just a hypothetical question: If we reference the picture I posted above, what happens if you were to close the valve on the surface skimmer and just used the underwater skimmer? I'm curious what happens when all the water gets sucked out of that pipe between the two skimmers....
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Hey! My pool is famous LOL! (Check link in my signature)
    There is only one skimmer, the other connection is the original suction port. There are no issues with running either or both, with the exception of reduced skimmer suction when the suction port is opened. If I close the skimmer valve, the water will most likely stay in the pipe from the slight vacuum created trying to pull it out. When I use the skimmer for my manual vac, I open the suction port, then close the skimmer valve to setup my vac plate & vacuum. When I re-open the skimmer valve, I do not see any noticeable air bubble flow through the pump basket, so the pipe must remain full.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Apr 2017
    Hamilton, IL
    17
    Quote Originally Posted by domct203 View Post
    Thanks so much for the information! I feel more confident about doing this now. Your pool is famous! Second image on my search! How do you like those GAME adapters? I want to use the intex hoses so I can store the pump for winter make the disassembly easy.
    domct203's Avatar
    Jun 2015
    CT
    3,890
    I love the intex hoses. Nice, secure connection that never leaks. I used them at the equipment pad as well, and the GAME adapters work great. I have bought a few shorter hoses from Intex's website for the connections at the pump this year.
    Dom - TFP Guide
    Apr 2017
    Hamilton, IL
    17
    Awesome! I like how simple yours looks and that it's maneuverable if needed and can be easily torn down for storage! Can't wait to get started
    Jun 2017
    Hillsboro, OR
    2
    I don't understand when they say "cut the gasket in half". Are there some better installation instructions on here, or a video that starts at the very beginning of the process? I love the idea of replacing the "hanging" skimmer.
    Intex 12x24 Ultraframe, saltwater & sand filter.
    jmcdtucson's Avatar
    Jun 2014
    332
    The gasket is like a sandwich with one side going inside the pool and one side going outside the pool. The slices of bread are connected by a thin rubber wall. Cut them apart.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    May 2017
    New River/Arizona
    3
    Welcome to TFP!!
    Attachment 64860Attachment 64861
    I basically copied DOMCT's setup, but I took my PVC down to the ground for extra support. I capped the second inlet, but wish I would have tied it into the return for running the Intex Auto Cleaner. I also added a second return port (vertical pipe) for a future fountain/aerator.
    I think the reason that some cut the butterfly gasket is so you can mount the skimmer without having to drain the pool below the skimmer area. Once they've mounted the skimmer with split gasket, they cut the vinyl out. If you can install the skimmer before you fill, you won't have to worry about cutting it!
    18' x 52" Intex Ultra Metal Frame / Intex Sand Filter / SWG / Hayward Skimmer
    jmcdtucson's Avatar
    Jun 2014
    332
    That's a nice looking setup BCunningham! What did you replace the Intex outlets with?
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
  20. Back To Top    #20
    Jun 2015
    Central Point Oregon
    21
    IMG_1975.jpgHere is my setup. Hayward wide mouth skimmer. Second outflow to the pump in case the water gets too low for the skimmer. 1 inflow to a homemade fountain and 1 to the pool. I cut out the Intex returns and replaced them with Hayward. I can remove the eyeball and screw in a pvc adapter and hook up my Intex pool cleaner or vacume hose.
    Intex 9x18x54 pool, semi hard plumbed with Intex 3000 gph Sand Filter and Intex SWG, Hayward fittings, Intex Robot pool cleaner.
