Results 1 to 12 of 12
Thread: What ones do i need HELP
    Jun 2015
    Michigan
    13
    With everyone talking about opening there pools, I have been thinking about ditching my swg and going with plain chlorine. So my question is what pool chemicals do i need, I am very new at this and would like to get it right the first and not be running around trying to find pool chemicals. I have a 18 foot ultra frame intex with a 3000 gal sandfilter the K-2006 test kit and a new bathing suit (last one fell apart because i dont know what im doing hahaha)
    Thanks Andy
    Intex 18x48 - Intex sand filter - Intex SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: What ones do i need HELP
    Most folks only need muriatic acid to lower PH and bleach to raise FC. More here, Pool School - Recommended Pool Chemicals and Pool School - Recommended Levels
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,299
    Andy,
    SWCG pools are the easiest pools to maintain, so why are you ditching your SWCG? Is it not working or ??
    Jun 2015
    Michigan
    13
    Quote Originally Posted by Jimrahbe View Post
    Andy,
    it just seamed last year it was not very consistent one day high the next day low on FC. Just thinking if i had the right cocktail of chemicals and which ones i needed it might be easyer to maintain
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,995
    Welcome to TFP
    When you say it wasn't consistant, can you tell us how you were testing the water?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Jan 2012
    'burbs of Augusta, Georgia
    8,585
    How often were you testing the water?
    You say it would go low..... was that perhaps after a mess of kids were in the pool say...and may have added a bit of organic matter to the mix?
    What were your CYA levels last year?
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Jun 2015
    Michigan
    13
    Quote Originally Posted by YippeeSkippy View Post
    Yippee
    well the water was being tested daily when it was being used alot but weekly other wise as for kids yes alot of kids. my test kit i was useing was a cheap one from Wallmart and only tested PH and Chlorine so now i have a K-2006 and i did not use CYA but im guessing i should be buying some. I was thinking all i need was the SWG. If I need to buy CYA what others are recommended,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    If you want to ditch it, go for it. Keeping your pool with manual additons of Chlorine will be a piece of cake. Keep a few jugs of Bleach on hand, along with a little Muriatic Acid and you'll be fine. You may need some Cyanuric Acid/Stabilizer to start, but it isn't needed often unless you lose or swap a good deal of water. You have a good kit, and you'll learn what your pool needs pretty shortly once you start regular testing.
    Essential Links:
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    Quote Originally Posted by andycam View Post
    Are you saying that you have CYA = 0 in your pool? You should have CYA of 70 ppm with a SWG. If so, this is one reason for having large swings in FC levels with nothing to buffer the FC.
    You should be testing for FC, CC, pH, TA, CH, and CYA and salt after major water additions. See the pool school section on Basic Schedule for tests and frequency. While you are there, browse through ABCs of Pool Water Chemistry and some of the other articles in Pool School.
    We can't really say what other chemicals you need since we don't have any test results
    Jun 2015
    Michigan
    13
    Thanks everyone all the info it was very helpfull so i will give it a try again this year, im sure there will be a lot more questions to be asked. But first i need to be a student of pool school.
    jmcdtucson's Avatar
    Jun 2014
    332
    SWG is the way to go in my opinion. Nicest thing for me is it maintains FC when I'm gone. Also you don't need FC levels as high and to many people the water "feels" nicer. It comes down to personal preference, but there's no reason you shouldn't be able to use an SWG and manage your levels with little effort once you get your CYA sorted out and have a little practice.
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    domct203's Avatar
    Jun 2015
    CT
    3,900
    Thanks Andy
    There is no difference in chemicals used between a pool that gets it's chlorine from a SWG, or from manual dosing.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
