Results 1 to 16 of 16
Thread: New test.
    Mar 2017
    Floresville, Tx
    24
    New test.
    Hello all. I drained about 1/2 of the water out of my pool due to high ch other levels. As it did lower some the math says to drain another 53%. I can afford to keep draining and refilling. Is there something I can add to get the levels in check? I also have very hard water if that comes into play. Thank you.
    fc 4.5
    cc .5
    ph 7.8
    ta 190
    ch 250
    cya 55
    33' round above ground. Sand filter.
    Mar 2017
    Floresville, Tx
    24
    Re: New test.
    I redid my cya test in a little better lighting and it was around 55.
    30,941
    Re: New test.
    That water does not indicate it is hard (high in calcium....mainly) Are you filling from a well?
    Mar 2017
    Floresville, Tx
    24
    Re: New test.
    No. Just hard water in general. It was so high in calcium before because I had too many tablets in it all winter thinking more was better in the winter months. It ended up costing me. Now it is bleach all the way.
    Jun 2007
    Houston, Texas
    212
    Re: New test.
    Yep, you need to stick with bleach from this point forward. Your CYA is on the high side already so you don't want to add any Dichlor or Trichlor which will raise your CYA. Cal Hypo will raise CH. Your CH is okay now but you don't want that get out of whack as before. Stay off the power, granules, hard stuff and stay with liquid bleach.
    Pool School - Chlorine / CYA Chart
    With a 55 CYA you need to maintain ~7 - 9 PPM Chlorine. You are too low right now.
    You need to stay within recommended levels at all times. Watch your PH and TA as well.
    36,000 gallon IG Gunite (40 x 20), 1.5 HP Hayward pump, Pentair Nautilus NS-48 DE filter, 2 skimmers, 12 - (2 x 20) Fafco Solar Panels (Goldline controller not hooked up yet), Hayward Swimpure Plus SWG, Blue Pearl Robot cleaner. New Dr. Wellness X-12 standalone Lifestyle Spa.
    Mar 2017
    Floresville, Tx
    24
    Re: New test.
    So with that being said. How much bleach should I add?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: New test.
    https://www.troublefreepool.com/calc.html
    Time for you to figure that out now! Plug in pool size at the bottom to get your gallons then plug gallons back in at the top.
    NOW column is your 4.5 and Target is where you want it to be.
    Mar 2017
    Floresville, Tx
    24
    Re: New test.
    So with the high cya I should have free chlorine around 7 to 9?
    Teald024's Avatar
    Aug 2016
    Lyme, NH, formerly Columbus, Ohio
    1,488
    Re: New test.
    Quote Originally Posted by Cduke88 View Post
    Welcome to TFP! Glad you found your way here.
    Short answer, yes. With a tested CYA of 55, round it up and assume you have CYA=60. Per the Chlorine / CYA Chart your absolute minimum FC should be 4ppm and NEVER lower. Your target minimum should be between 7-9ppm. If you know your daily FC burn off is 2-3ppm, then aim and dose to 10ppm and add if below 7ppm. You will need to do this test and add daily.
    30,941
    Re: New test.
    Okay, this thread needs to take a deep breath.
    1. In a climate like Texas, I would not call that CYA too high. TFP would suggest 40-50 as standard so, since the accuracy of the test is around + - 10 ppm, you cannot safely say that a newbie report of 55 ppm is too high.
    2.
    I assume you mean "can't afford, right?
    3. What levels do you need to "get in check"?.....I don't see any real problems with the numbers you post
    Apr 2010
    East Texas
    10,152
    Re: New test.
    My CYA is 40 this a.m. and headed up to 50 by this afternoon. I guarantee it'll be headed to 60 mid-July!
    Mar 2017
    Floresville, Tx
    24
    Re: New test.
    Right. Cant afford. I just thought the cya was supposed to be lower. That's all.
    Jun 2007
    Houston, Texas
    212
    Re: New test.
    He mentioned that he drained half his pool and his CYA was 55 after draining, so I assumed his CYA and CH was high which caused him to drain. For that reason along with him just recently draining is why I mentioned that he should stop adding Dichlor, Trichlor or Cal Hypo moving forward. Sounds like that's the source of his problem? His wording wasn't real clear, so I'm not sure what he means when he says the math tells him to drain another 53%?
    Jun 2007
    Houston, Texas
    212
    Re: New test.
    cduke - look at the recommended pool levels here... Pool School - Recommended Levels
    Mar 2017
    Floresville, Tx
    24
    Re: New test.
    Thanks guys. I am sorry if I am confusing anyone. I am figuring this out more and more everyday. I think my levels are in reason now looking at everything. With the higher cya I just added more bleach to raise my fc.
    triptyx's Avatar
    Apr 2016
    1,475
    Re: New test.
    No need to be sorry, we'll help you through it. It seems like there's a ton to learn when you first get started, but in no time, you'll have a good handle on what you need to do.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
