Results 1 to 13 of 13
Thread: After two years, I finally have to ADD CYA
    Jun 2016
    Lake Dallas, Texas
    73
    Now the question, does the brand matter? I won't be getting liquid. If I understand, just put the powder in a sock and put the sock in a skimmer basket?
    Thank You,
    Bryan
    33,000 Gallon In Ground Gunite/Plaster
    1.5 HP Pentair Wisperflow 2 speed pump and Pentair 60 DE filter
    3/4 HP Pentair Booster pump and Polaris 280 cleaner
    Cirrcupool SJ55 SWG. TF100 test kit
    Curtsam's Avatar
    Aug 2013
    Eastern Oklahoma / Arkansas
    33
    Re: After two years, I finally have to ADD CYA
    Brand does not matter.
    Do not place in skimmer basket. Place the sock in front of one of your return jets.
    Greg
    2014, IG 20,000 gl 18x34 Vinyl Liner / Waterfall / SWG / Sand Filter /
    Dolphin M4 Robot / TF-100 Test Kit is used / Beer is consumed /
    *Stamped Concrete Decking*
    Jun 2016
    Lake Dallas, Texas
    73
    Gotcha, Will do. Thank You.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,895
    Actually, in the skimmer is OK as long as it doesn't block all the water flow.
    Support the site
    Jun 2016
    Lake Dallas, Texas
    73
    ThankYou
    Jan 2012
    'burbs of Augusta, Georgia
    8,563
    Quote Originally Posted by tim5055 View Post
    If you put it in the skimmer as Tim says, make sure you keep the pump running until it is all dissolved so that you don't have it sitting there in stagnant water getting very acidic. Then when you do turn the pump back on you are sending a big bolus of acidic water thru your pump (think gaskets and such) which isn't so good.
    So off the side of the pool (not touching the walls) or in the skimmer.... your call. I prefer to hang it from some pool noodles and let it float around. I can make an "X" out of pool noodles and rubber bands so it won't touch sides of the walls.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Walmart HTH dissolves really well. And I use a Knee hi with a knot in it.
    Jun 2016
    Lake Dallas, Texas
    73
    All great ideas. ThankYou.
    BattleOfYakima's Avatar
    Apr 2016
    Central Florida
    1,667
    Quote Originally Posted by woodyp View Post
    Ditto! Did the same with the same and it was gone by sunrise.
    If you're the see it before you do it type: video of it hanging in front of return https://1drv.ms/v/s!AoOtP08Bbf0YgXs_XMjx0w-YB7oi
    (it will go at a very reasonable pace if you leave it alone, or if impatient, you can massage it, but i'm not promising that's safe - both shown in video)
    and picture of how i hung it: https://1drv.ms/i/s!AoOtP08Bbf0YgW6JKfZO4OSv7SQI
    and a picture at night because I thought it was cool: https://1drv.ms/i/s!AoOtP08Bbf0YgWf9tmj25tb6ZJOz
    If I was effective, and your pool makes you smile, please make me smile and CLICK HERE to Become a TFP Supporter!
    Also, please make AmazonSmile donate to TFP by CLICKING HERE, at no cost to you!
    My Florida Pool: 20k IG plaster cart K-2006 | Washington State Pool I help with: 17k AG vinyl sand TF-100
    Jun 2016
    Lake Dallas, Texas
    73
    I put 3 pounds in skimmer sock, and then put the sock in my pool net at the end of the pool pole. The net on the end of the pole was dangled in the water about two feet in front of a return jet. The other 3 pounds were put in a skimmer sock, and the sock was placed in the bottom of the skimmer. Now, I could have put both bags in either the pool net, or the skimmers. But I was experimenting with which one dissolves faster. The bag in the skimmer dissolved much faster by the way.
    Bryan
    Apr 2016
    Central Florida
    1,667
    Glad it went well. Remember that it can take up to a week to get an accurate CYA test result after adding and best to avoid backwashing if possible for at least a couple days.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    TFP used to say a week, but we don't any longer. Once all the Cya is completely gone from the socks it should take no more than a day of normal circulation maximum for it to show up.
    Essential Links:
    Jun 2016
    Lake Dallas, Texas
    73
    Thank You for all of the information.
    Bryan
