Results 1 to 9 of 9
Thread: Hayward AquaRite info not showing on AquaLink RS All Button
    Apr 2017
    Cypress, TX
    23
    Original pool with AquaLink RS control system was converted to salt years ago. When Hayward (originally Goldline) SWG was installed, the tech "upgraded" the AquaLink RS with a module that could read the SWG salt levels and allow me to super chlorinate all from the AquaLink RS controller mounted in the house.
    This has worked flawlessly for at least 8 years, but now I can no longer see anything on the AquaLink RS about the SWG.
    What should I check? How should I troubleshoot?
    Re: Hayward AquaRite info not showing on AquaLink RS All Button
    What are the diagnostic readings on the aquarite box?
    Does AquaRite say "Remotely Controlled"?
    Support the site
    Apr 2017
    Cypress, TX
    23
    AquaRite does NOT say "Remotely Controlled". In fact, when it was working, I don't remember it ever saying that....but could always be mistaken.
    Apr 2017
    Cypress, TX
    23
    Quote Originally Posted by JamesW View Post
    Did some more digging and decided to open up the Jandy AquaLink RS Control Panel. Found what I think is the correct wire (gray) going from the AquaRite (1st picture) over to the AquaLink. Looks like that is my problem, since it's not connected to anything.
    Where should it connect?
    I initially thought it should go to the black wire (3rd picture) that is also not connected, but now think that is the 2nd controller that is beside the hot tub. That controller isn't working either & have no idea where it should be connected.
    Apr 2017
    Cypress, TX
    23
    Anyone have any suggestions?
    May 2013
    23
    Quote Originally Posted by gbrenham View Post
    Just noticed you post. Have you been able to get it working? The grey cable has you did see has 4 conductors in them. If you trace the other end back to the Jandy box is it connected to anything? Be careful when in the Jandy box. There is a high voltage area and a low voltage area. The cable should run in on the low voltage area and up to the Jandy board. If it is connected, it will be connected to the reddish orange 4 pin connector. This is the RS485 communications connector. Seeing the picture of your Jandy, you have an older version, but we still need to know the revision of the Jandy software. As for the end you pulled out of the SWG, it will connect to the same type of connector on the SWG. It in the upper right hand corner. If you look on line for the AquaRite manual, the older manuals will tell you how to connect the SWG to the Jandy. Now the one thing that might be a problem is that if you Jandy software is rev L or newer, the 2 will not work with each other.
    This is hat you might want to do.
    1) Make the RS485 connection between the Jandy and AquaRite.
    2) See if the 2 device will work with each other. If the Jandy shows you the AquaRite in the device list, without the words (NOT COMPATIBLE), you are all set. IF NOT COMPATIBLE go to step 3. If the Jandy doesn't see it, check your wiring.
    3) Set your AL to AL-5 on your SWG. If you don't have a AL-% you are done and see next paragraph.
    4) Power cycle your system and see if you see in the device list AquaPure. If so you are done. If not, see next paragraph.
    Since you are reading the paragraph, the 2 devices didn't work together. If you look in this form, you will see people talking about the Chlorinator Translator. You might want to check that out.
    Jandy iAqualink RS-8 Rev T, OneTouch, Chlorinator Translator, & AquaRite Rev 1.3
    Apr 2017
    Cypress, TX
    23
    Thank you so much for your reply! I'm just now back on the forum.
    This worked at one time and no upgrades have been done, so I think the whole "NOT COMPATIBLE" issue and software revision is a non factor. I believe it's a connection issue for sure, but have been unable to find any documentation on how it's supposed to be connected.
    The 2nd picture shows a gray wire (with orange, black, white, brown & blue) coming from my AquaRite Salt system to the Jandy box. You are saying that this needs to be connected to the reddish orange connector in the Jandy box (directly above the "Reset" button) on the Jandy control panel. Is that correct?
    If so, there is already something connected to it (green, yellow, black, red wires - see 3rd picture)
    If this is not correct, maybe if you could give me the connector designation (ex. TP30, J14, etc.)
    Size: 18K gallon salt Type: In ground w/ colored plaster Features: Waterfall, Hot tub (no heater-rusted out Hayward H400) Age: 20+ years Control System: Jandy AquaLink RS (RS8) Pumps: Main - Century Centurion 2HP (B230SE) Booster - Century Centurion 3/4HP (B625) Waterfall - Century Centurion 1HP (B128) Filter: 4 cartridge Hayward Super Star-Clear (C4000) Test kit: TF-100 Cleaner: Polaris 380 Other: SWG is original Goldline (now Hayward)
    Jul 2015
    243
    Exclamation Re: Hayward AquaRite info not showing on AquaLink RS All Button
    Color codes could be off so just make sure wiring is set from pin 1 to pin 1, 2 to 2, etc. BUT (big but) before doing so, make sure you perform these steps in the following order. Jandy could lock out all SWCGs unless this is followed to the letter:
    1) Program the SWCG to emulation mode AL-5 and let run for a minute or two
    2) Power down both the SWCG and the RS-8 from the circuit breaker
    3) Make your connections (pin 1 to pin 1, etc...)
    4) Power on the breakers
    5) Watch the SWCG to see if the "remotely controlled" LED is lit. Should illuminate with the first minute of getting power.
    6) Check the RS-8 remote display to see if the SWCG now shows as "Aquapure" (this is what emulation does - makes the Hayward appear to be a Jandy).
    If emulation mode is set to anything other than AL-5 while connected, the RS-8 could recognize the SWCG as non-Jandy and kill remote SWCG functionality. Only re-flashing the chip will restore it regardless of the brand.
    16,500 gallon IG Pool & Spa: Intelliflo VS pump, Pentair Triton II TR-100 sand filter, Teledyne Laars Lite2 propane heater
    Laminar Jets (2): Hayward Maxflow SP1600 1/2HP, Hayward Star Clear C500 cartridge filter
    Jandy iAqualink RS-8 Rev T, Hayward AquaRite AQR15, Dolphin Supreme M5, Taylor K-2006, Taylor K-1766
    May 2013
    23
    The reddish orange connector is a RS485 interface. It is design to have multiple devices connected to it. So you can place more than one wire in each of the screw terminal connection. Just note what wire you put in each position as Uncle Flappy told you.
    Waiting to hear if you get it working or still have issues.
