Results 1 to 9 of 9
Thread: Polaris 280 Issues/Advice
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Been getting my Polaris tuned up for the pool season. It came with the house I bought last summer and I am unsure of the age. It's at least a few years old. I'm sure it's just me, but it feels like this thing constantly needs tuning and repair for it to work ideally.
    I was having issues where the wheels weren't turning (one side was, but it wasn't turning the others, even after rotating). I ordered new wheels and new drive shaft and bearings. The new wheels got to me first and I put those on and it was really working great. I should've just left it at that. When the new drive shaft and bearings arrived, I decided to go ahead and put those on too. Well, now the dang thing is moving slow again. I watched a couple youtubes on how to install the driveshaft and I don't see how I could've done it wrong.
    Tonight, I'm going to put the old one back on see what happens, but does anybody know what could cause this? Is there a special step I may have missed?
    Memphis, TN.
    Pool IG, 20K gallon, Gunite. Triton Sand filter, Pentair Pump, Polaris 280, Doheny Discovery Dolphin, Chlorinating Liquid, Rock Water Feature, New Plaster 2015
    Spa 450 gal, Tropic Seas Waikiki 864L, Bromine
    Taylor K-2006
    Jan 2014
    Brookhaven, MS
    45
    Re: Polaris 280 Issues/Advice
    Are you sure the screen filter is clear and not blocked with any debris?
    18x36 25k Gal Inground Vinyl Pool
    300lb Sand Filter / 1.5hp Single Speed Pump / Intellichlor IC40 SWG / Polaris 280 w/booster pump
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Quote Originally Posted by rmasonjr View Post
    Yes. Now I guess it's possible I didn't put something back on exactly right and maybe it's not getting the needed flow.
    I will say that when I put the driveshaft in and attempted to spin in before putting everything back together, it didn't just spin as freely as I would've expected (or like it did on the youtube I watched).
    Memphis, TN.
    Taylor K-2006
    Jan 2014
    Brookhaven, MS
    45
    Maybe check the wheel screws and make sure they are not over-tightened or binding against the bearings.
    Sure is strange that a rebuild would have that effect.
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Yeah so you're on to something. When I leave the screws loose on the bearings it spins fine. When I tighten them down to where I think they need to be, it slows the spin. Put the old bearings in and they don't do that. Weird.
    Memphis, TN.
    Taylor K-2006
    Mar 2014
    Arizona
    36
    One problem I had when I rebuilt mine was I had the tail flow "screw" set to too much flow out the tail. It's the large allen head bolt near the float.
    Because so much pressure was going out the tail, not enough was flowing into the gears to make it move with enough force.
    I believe the factory setting is to screw it all the way in, then back out 1.5 turns. Once I set it to this, the wheels turned much quicker.
    I'm surprised this part of setting it up is not discussed more often, just about every rebuild instruction barely mentions it.
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Agreed. I just hand tightened it last time and think that contributed. I'm running at 33 rpms right now but it doesn't seem like it's going to fast.
    Memphis, TN.
    Taylor K-2006
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Couple things still don't seem just right. The front wheel seems continually "pop a wheelie". I keep adjusting the back jet thing but I can't find a sweet spot.
    Also the backup jet seems to come on an awful lot and runs longer than it needs. The hose ends up wrapping up in itself.
    Memphis, TN.
    Taylor K-2006
    Jan 2014
    Brookhaven, MS
    45
    For the back jet, the 11 o'clock position works for me.
    I recently removed the backup valve and run without it. Mine was acting up too...
