Thread: tile repair
    Sep 2015
    Austin
    137
    tile repair
    HI eweryone,
    I'm about to refill my spa with fresh water and thought I would do some tile repair whilst it was empty.
    I have a couple of small tile pieces that have come off, exposing the mortar (?) underneath. Any ideas of how to go about this?
    thnks
    Karen
    26,390 gallons IG, Centex plaster, Hayward DE 4820 filter, Century Centurion B2859 pool pump motor.
    Booster pump for polaris 280
    Spa
    Built 1997
    JoyfulNoise's Avatar
    May 2015
    14,083
    Re: tile repair
    Picture would help. Usually you need to remove and clean away all the old dried glue, clean up the exposed gunite, glue new tile on and then re-grout.
    Tile doesn't usually pop off. Does it look like too little glue was used? Are these 6" tile or 1" tile?
    Matt
    Sep 2015
    Austin
    137
    Re: tile repair
    thanks Matt, I've attempted to upload the photo of the tile. The water is lovely isn't it!! Not sure why it has come off, all the others look fine.
    Spa
    Built 1997
    May 2015
    14,083
    Re: tile repair
    I suck at tiling so take whatever I say with a grain of salt and hold out for better advice. That said, it's not so bad looking. The repair will just involve getting rid of all that tile glue on the gunite surface and the back of the missing tile piece. Once clean, just glue it back into place and regrout. The hard part will be getting the new grout to match the old grout. If you can't find an exact color match, I would get a bag of unsanded white and grey grout and try different blends until you get a good match.
    Perhaps our construction experts can give some guidance on the proper types of glue and grout to use.
    Matt
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,150
    Re: tile repair
    There are many you can choose from but for simlicity sake, here's a simple one-two punch after you clean out the old material as Matt mentioned.
    This one is to attach the tile...
    https://www.amazon.com/dp/B00Q2L3PZI..._t2_B00L3LXITK
    This one is to grout the tile...
    https://www.amazon.com/Pool-Patch-Wh.../dp/B00L3LXITK
    These are the white versions, also available in grey.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Apr 2015
    tucson, arizona
    1,311
