Results 1 to 12 of 12
Thread: Inconsistent CYA readings
    Jan 2017
    Elk Grove, California
    8
    Hi everyone... I'm a new pool owner. I recently purchased a house with a pool and I have no idea what I am doing. I just received my K-2006 test kit but I am not sure if I am getting correct CYA numbers. Every other test were pretty consistent between my results, Leslie's pool, and the aquacheck strips. I'm not sure which results to use, mine or Leslie's.
    Over the weekend, I went to the local Leslie's to test my water and here is what I got on 4/1:
    FAC: 4
    TAC: 4
    CH: 300
    CYA: 60
    TA: 80
    pH: 7.5
    TDS: 1400
    Pho: 100
    Results with Aquacheck strips on 4/1:
    TH: between 250-500
    TC: between 5-10
    FC: 5
    pH: between 7.2-7.8
    TA: 80
    CYA: between 50-100
    My own test results on 4/2 after adding roughly 170oz of 8.25% bleach on 4/1.
    FC: 7.6
    CC: .4
    pH: 7.6
    TA: 80
    CH: 320
    CYA: 120 1:1 diluted (Aqaucheck strips showed less than 100 CYA)
    My results today 4/3:
    FC: 5.5
    CC: .5
    pH: 7.5
    TA: 80
    CH: 330
    CYA: 90
    ~38,000 Gallon In-Ground Plaster | Sta-Rite Intellipro 2 VST | Pentair CCP420 Filter | Polaris 360
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Inconsistent CYA readings
    Welcome to TFP!
    We will always trust your K-2006 or TF-100 test results, you should too. Toss the test strips in the trash and stay out of the pool store for water tests.
    More detailed test instructions here, Pool School - Extended Test Kit Directions
    Jan 2017
    8
    Thanks pooldv! I'll have to read the directions and try again.
    domct203's Avatar
    Jun 2015
    CT
    3,892
    Quote Originally Posted by DaytonaMax View Post
    Welcome to TFP!
    Are you doing the CYA test outdoors on a bright sunny day, with your back to the sun?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jan 2017
    8
    I did it indoors. Anything special that I would need to do? I haven't had a chance to read the instructions from the link yet.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    The kit instructions should tell you all you need to know, bright light at your back, outside.
    Essential Links:
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    236
    After your sample and reagent is mixed up you can run the test multiple times if you need to, just pour the contents of your tube back into the sample bottle and run the test again.
    This way you can try again to see if your result changes, view it under different lighting or you can even have someone else give it a try and see what they get.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    Jan 2017
    8
    Thanks everyone. I'll have to try again later today.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,125
    Also, to add, .... the water needs to be at room temp or above when testing for CYA. If the water is below 70 ish, bring it inside and let it warm up before testing.
    When testing CYA, the light conditions are very important. Always test outdoors in a sunny spot with your back turned to the sun. Also, when holding the test tube, hold it with only 1 finger and your thumb. Holding it with multiple fingers restricts the light from shining in through the side of the test tube and giving you an accurate result.
    Also hold the test tube at waist level when adding the solution and viewing the black dot.
    The measurement accuracy of this test is about +/- 10 ppm,
    Divin Dave,
    Jul 2012
    Dallas, TX
    179
    's about CYA testing.
    I try to test my CYA when the sun is at it's meridian ~ an hour or so (testing only on clear days) on the day I test, to test when sunlight is at or close to its maximum level.
    - Pool Type: 15k Gal Gunite IG non-SWG / Built 1988
    - Pump: Pentair Challenger / Sweep Pump: Letro Model LA01N .75HP Single-speed / 6 hrs-day (1 turnover)
    - D.E. Filter: OEM: Nautilus (Pentair) #NS 36 / 36 Sq Ft / D.E. Charge: 3.6 Lb
    - Pentair 4-wheel Sweep LL505G - Booster Pump runs ~2 hrs/day
    Jan 2017
    8
    So I tested the CYA again today. I got a reading of 70. Thanks again everyone for all the help!
    FLPoolDIY's Avatar
    Aug 2016
    Land O Lakes, FL
    102
    I've done the CYA test multiple ways and typically have the same result.
    How I've done my test:
    1. Indoors held test tube at waist level and filled while glancing at black dot until no longer visible
    2. Indoors filling to each line and viewing at waist level until black dot is no longer visable.
    3. Placed tube on counter on a white piece of paper and filled to each line until the black dot was no longer visible
    4. Outside as defined on the instructions
    I've done all four with the same sample and had the same result. I think the key is to have bright enough lighting/sun for the test to be valid.
    As an added sense of accuracy I've used my ColorQ digital tester for CYA and its been within 10 ppm of what I visually identified with the test tube.
    When I first started doing this test it would drive me nuts 🥜 looking for the black dot to disappear.
    My neighbors were always curious what I was mixing in the little tube when I first started testing outside.
    FL, 15K gal (15x30 rectangle beach entry), IG Plaster, 2010, 1 skimmer, 4 returns, ecostar VSP, Pro Clean (PCCF-125) cartridge filter, IC20 SWG, Hayward Navigator floor suction cleaner, solar heat, waterfall, 2 lion head spouts, 1hp pump, TF-100 w/SpeedStir
