Results 1 to 7 of 7
Thread: Pump Water From Pool
    Mar 2017
    Naples/FL
    73
    I've only made a few posts but I've been reading this great Forum for several months now.
    Our new pool is an 8x50 swim lane, sun shelf and spa. The builder didn't include a valve, like we had on the older prior pool, that allows water to be pumped out of the pool. (We're in Collier County, FL if that matters.) The calcium hardness is at 450, the upper end of the recommended range and I'd like to be prepared to remove water if we need to.
    Is it still the norm for new pools to be built with a bypass that allows water to be pumped out of the pool? Or is there another approach I should take.
    17,250 gallon plaster pool & spa, IC40 SWCG, Cartridge Filter, CYA 70-80, Boric 50 ppm, Temp~84F, Naples, FL.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,303
    Re: Pump Water From Pool
    If you're handy, you could cut into the pump outlet pipe and install a tee and then a hose bib. That way you can connect a garden hose to it and run the excess water wherever you want.
    If you're not handy, a cheap submersible pump is probably the simplest solution.
    Either one will be cheaper than hiring a pool "pro" to do something.
    Mar 2017
    Naples/FL
    73
    Thanks Richard. I was also thinking that I could take the top off the cartridge filter and then let the pump run on low speed but that seems a bit crude.
    So is it usual for pools to not have the drain spigot?
    Richard320's Avatar
    Jan 2010
    20,303
    Quote Originally Posted by Naplespool View Post
    Yes. It's also common for the plumbing to be a convoluted rat's nest with no unions and no long straight sections to allow you to put one in later, either.
    Mar 2017
    Naples/FL
    73
    Thanks. I'll see how this goes. I realize that we're headed toward the rainy season so I'm probably overthinking this issue.
    Jul 2014
    Sacramento, CA
    243
    What cartridge filter do you have? It might be possible to replace the drain plug with a threaded fitting, valve, and hose adapter as I did:
    Replacing Pentair CCP drain port with a valve and hose attachment
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Mar 2017
    Naples/FL
    73
    Great suggestion. I have a Pentair Clean & Clear RP 150. It seems to have a cap rather than a plug. I will look into it further.
