Thread: Low salt cause need for SLAM - when to add salt?
    Newpoolcrazy's Avatar
    May 2015
    La Porte, TX
    104
    Husband was supposed to add salt to the pool before going out of town and forgot. I came home a day later to find a cloudy pool with greenish tint. Salt was below 2700 so SWG had stopped generating.
    2 days in, OCLT this morning showed a loss of 1.5 FC and CC is at .5ppm Still a little cloudy but looks much better. Will keep slamming until all 3 criteria are met, but when can/should we add salt? Would like to do that while we are already running pump 24/7 without SWG but worried it might mess up my FC/CC readings.
    Cornelius Monterey Steel/Resin AG 18' round (approx. 7600+gallons) Hayward veri-flo SWG w/sand filter.Testing w/ TK2006 using Speed stir.
    mas985's Avatar
    Pleasanton, CA
    11,987
    Re: Low salt cause need for SLAM - when to add salt?
    Add salt whenever the unit requests it or periodically check the salt level and it is getting close to the lower end of the range.
    Mark
    May 2015
    La Porte, TX
    104
    Quote Originally Posted by mas985 View Post
    We just dropped the ball due to family problems. But is it okay to add salt while we are slamming since only the pump and not the SWG is running 24/7?
    30,960
    Yeah, it's fine to add the salt anytime. I think you are saying that you are SLAMming using liquid chlorine, right?
    Just keep doing that and finish SLAM without the SWG on but ready to go.
    Then, when your SLAM is finished (sounds like you are close), let the FC come down to normal and turn on the SWG.
    mas985's Avatar
    Pleasanton, CA
    11,987
    Anytime is fine.
    Mark
    May 2015
    La Porte, TX
    104
    Yes, I'm using regular 8.25 regular chlorine bleach. It looks like I AM close, but no cigar until that CC is at 0. I don't care how good it looks!!
    Thanks. Will have hubs add salt tonight.
