Hi there!
I've recently noticed a small amount of greenish algae (or what I assume to be some type of biological material) at the bottom of my pool, hovering around the center drain. The rest of the water is clear and sparkly, and this morning's levels are as follows:
FC 3.2
CC 0
pH 8
TA 100
CH 360
CYA 30ish
Salt 3300
Temp 76
I have persistently high TA, which is why my pH drifts up so much, and I add acid about every other day. These results are from before I added acid this morning. Also, I'm aware that I need to add some stabilizer to get that CYA up, I just haven't made it to get some yet this season.
If I can remember how to add some pictures I will, but since my water is clear and my CC is zero, do I really need to go through the SLAM process? Would I need to do an OCLT to be sure?
Chelsea
If it helps, I'm located in a Southeast Louisiana and my pool is in full sun. Other details in signature.
FC 3.2
CC 0
pH 8
TA 100
CH 360
CYA 30ish
Salt 3300
Temp 76
Chelsea
