Thread: Leaf skimmers...
    Leaf skimmers...
    What are the advantages/disadvantages to the flat, open faced leaf/debri bottom of the pool skimmers vs the type that has more of a closed end net basket type design? Brands you can recommend?
    22,500 gal A.G., vinyl, sta rite crystal sand filter- Pentair Water Pool & Spa , Hayward Super Pump Self Priming 10" lift, BBB method
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    34,004
    Re: Leaf skimmers...
    The flat ones are great for skimmer the top of the pool fast. They don't old much so if you have a heavy load the open net kind is better. The open net kind is MUCH better for cleaning the bottom as well. I buy mine at Walmart or Lowes depending on where I am when I need one.
    Kim
