Results 1 to 7 of 7
Thread: Pool filter sand help...
    Mar 2016
    Easley, SC
    406
    I recently renovated my pool pad and now I need to fill the sand filter with new sand. I found some at Home Depot but wasnt sure if it is compatible with my filter. Can anyone give me some guidance/advice on this?
    Here is my filter label
    Here is the sand that I found
    Quikrete 50 lb. Pool Filter Sand-115350 - The Home Depot
    18x36 inground / 28k gal / Vinyl liner (replaced in 2018) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump / Stenner pump (85MHP17) w/55 gallon storage tank / Pentair heat pump HP1200 (To be installed) / TF100 Test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Re: Pool filter sand help...
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    What did you do with the sand you took out? There is no reason not to use it unless it was all stuck together by pool $tore magic potions.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mar 2016
    Easley, SC
    406
    I will take a look at that link.
    I purchased the house last year and have no clue what all the sand has been thru. I dump it all out with plans to replace it so I know what I am working with.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    Oh that's a bummer. But it is what it is. That link should prove helpful.
    Mar 2016
    Easley, SC
    406
    Agree.. With the amount of things I have found with this pool from the previous owner I would not be surprised if it had play sand in it. I do know I would get little patches of sand in the pool last year. I figured one of my laterals was broke. It all looked good once I got all the sand out. After reading the above post I think I will stay away from the Quikrete and go with the HTH. Just hope someone local has it.
    Jun 2016
    Central Oklahoma
    83
    Last year I had some white beach looking kind of sand now I have the hth brand. Always had sand in the bottom of my pool.
    May/2018 AGP Coleman 24x52 vinyl, 13.6k gallons, Harris H1572228 Vortex 16 inch Above Ground Sand Filter System with 3/4 HP Pump, PoolBlaster Max, TF-100
    Run pump 24/7
