Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Sand coming out while backwashing
    Apr 2017
    McAlpin/FL
    13
    We just purchased a used sand filter. Q: why is there tons of sand coming out of hose when backwashing? Very little water
    40,831
    Re: Sand coming out while backwashing
    Welcome to TFP!!!
    Who installed the sand filter? What is the model number? How much sand was added?
    What type of backwash valve do you have?
    Can you post a picture of the plumbing?
    Apr 2017
    McAlpin/FL
    13
    We installed. I'll get model number an name of manufacturer the backwash value you have to push down turn to slot and release and yes I will post a picture of the plumbing that me and my husband done not the greatest I guess we're trying the directions that came with the pump might as well be in another language other than English. Oh wait it does. Lol. because I don't understands it. Info on dials are nothing, basically nothing about pressure anything so we've been working on info from google we put a hundred and fifty pounds of sand in
    Apr 2017
    McAlpin/FL
    13
    I just purchased a long backwash hose ,
    40,831
    What is the filter size? You posted pictures of the multi-port valve and the pump stickers, but not the filter.
    It looks plumbed correctly. Is there any way the top portion of the valve could have gotten clocked to the wrong position?
    What sand did you use?
    When did you see all the sand coming out, was it really in the backwash position? The picture is in the Rinse position.
    Apr 2017
    McAlpin/FL
    13
    Yes it was in the backwash position. An when u say what filter size is,that the container with the laterals in it other than that I don't know where any other filter would be. We purchased sand for it at a pool store they were 50lb a bags. An sand came out after we loaded it an filled it with water the first time an tried to backwash sand as the pool store told us to do before use on pool.
    40,831
    The filter is the big tan thing
    Did you avoid pouring sand into the central stand pipe?
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,241
    pink,
    I do not own a sand filter, but would "assume" that after initially filling it with sand, that you would get a little sand in your first backwash.
    How much sand came out and how long did you run it?
    Have you tried it again?
    Apr 2017
    McAlpin/FL
    13
    Yes there was a device to cover the hole.
    Apr 2017
    McAlpin/FL
    13
    Quote Originally Posted by Jimrahbe View Post
    pink,
    Yes , I've tried it 3 times an the amount of sand was about 30 cups full at a good guess .after trying g 3 times we had to add more sand.
    Jul 2014
    Bedford, TX
    9,241
    Pink,
    I'm with you... Something is wrong...
    Maybe one of our members with a Sand Filter can chime in...
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    686
    It is possible that you've over filled it with too much sand. If it's a model SD35 than it only needs 100lbs not 150. Anytime a sand filter has too much sand it will naturally expel the excess during backwash until it gets to around the correct filled level. When back washing all the sand is lifted and as this happens the dirt is displaced and lifted through the grid on the underside of the multiport. If theres too much sand the water pressure during back washing will force all that extra sand up higher and out to waste.
    If it happens to be a SD40 then it does require 150lbs of sand and there is something seriously wrong with the multiport.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    I think that the problem is probably due to the pump being oversized for the filter.
    Support the site
    Apr 2017
    McAlpin/FL
    13
    It was bought together in same box. So don't think that's problem. We are just going to start over take it apart an retry.. thank for all the questions ..
    Apr 2017
    McAlpin/FL
    13
    IT'S A SD40 150 LBS OF SAND IS THE REQUIRED AMOUNT. THANK YOU FOR THE QUESTIONS. WE'RE JUST GOING TO START AS IF IT WAS NEW AN SEE IF THERE WAS A MISTAKE WITH ASSEMBLY, SENCE IT WAS USES WHEN WE GOT IT.
    Apr 2017
    McAlpin/FL
    13
    Pink,
    Yeah , there is .. we are going to start from ground 0..thz
    The backwash rate for that filter should be about 28.5 gpm. The pump can do about 80. The pump is 2.8 times too big for the filter.
    Support the site
    Apr 2017
    McAlpin/FL
    13
    Then why were they sold as one unit from SAM'S ? if motor is to big for filter. That makes no sence to me please explain so I can ask manufacturer
    domct203's Avatar
    Jun 2015
    CT
    3,890
    James has already explained the issue, the pump will push almost 3 times the amount of water that the filter can handle during backwash.
    I can't explain why SAM's paired them together.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
  20. Back To Top    #20
    Apr 2017
    McAlpin/FL
    13
    Okay thanks. Not sure why they would sell this an a unit , I'll have to talk to manufacturer see why that they're misleading their customers by selling improper products together thank you guys for your help have a good day
