Results 1 to 7 of 7
Thread: Green Opening Question
    Apr 2015
    Leesburg, GA
    49
    I have a 20', 52", above ground Intex pool with sand filter. The water has turned green over the winter. Should I drain the water and start over or should I add chlorine and work on clearing up the water that is in the pool? (I have a well)
    My sand filter has been in operation for about two years. How do I know when it's time to replace the sand and if I try to treat and clean up the green water will that cause me to have to change out the sand much earlier than normal?
    20' Intex; 52" deep; 8,638 gal; above ground. Intex 1,600 GPH sand filter.
    Donldson's Avatar
    NW Ohio
    3,208
    Re: Green Opening Question
    Sand in a filter has a lifespan of about 100,000 years so you should be good for now.
    How green is the water? Pea soup? Just a tinge? What are your initial test results?
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    appstategrad's Avatar
    Jul 2014
    Hickory, NC
    162
    Quote Originally Posted by Donldson View Post
    ~ 18.5' x 36.5' inground Grecian pool with vinyl liner
    ~ approximately 23,000 gallons
    ~ AquaRite Salt Water Generator cell size t-9
    ~ 1.5 HP Hayward Pump and Hayward Sand Filter
    ~ TF-100 test kit
    Apr 2015
    Leesburg, GA
    49
    It's pea soup. I'll test it shortly.
    Jan 2012
    'burbs of Augusta, Georgia
    8,546
    How easy is it to pull 9K gallons of water out of your well at one time? Some folks would find it a problem so we'd say treat the water in there.... others not.
    Does your well have iron in it??
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Sfpat's Avatar
    Jul 2016
    tulsa
    113
    Slam the pool as recommended per this site. Your pool will be blue in a couple of days
    40 year old pool, 35k gal w/spa, gunite replastered July 2016, Hayward Sand filter, Hayward 1.5 hp single speed pump, TF-100, Kreepy Krauly suction side cleaner Dolphin M400
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Start with some test results. If CYA or CH are really high due to chlorinating with pucks or powders, you'll want to replace some water anyway.
    If it turns out there is no CYA, start by raising FC to 10 and let it circulate for an hour or so and then recheck FC & CC. If CC is huge and FC is all gone, then you likely have an ammonia situation and a drain is probably cheaper than trying to eliminate it all with bleach.
    If CYA and CH are low or okay and you don't get the huge CC reaction, then just go ahead and SLAM. A note: the more organics you remove early on -- leaves, twigs, dead critters, whatever -- may be lurking on the bottom, the faster it will clear.
    Start by getting the water circulating and then test and post results and someone will be along to advise.
