Results 1 to 17 of 17
Thread: Pool store and my test.
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    So I have been checking my water everyday for the last couple of weeks and thought I'd compare my results to the pool store. They have the BioGuard system.
    My Taylor kit is reading 0 CH the pool store says I have 278 Total hardness...I understand this also includes Mag. But shouldn't I be reading a little CH?
    My Taylor kit is reading 110 TA the pool store says Adj. Total Alkalinity 35.
    Pool temp is 62 degrees. My FC is 11.5 coming down from shock. Could my FC make my readings off?
    7000k Viking fiberglass Bermuda, Sand filter w/glass, Pentair SuperfloVS, Pentair IC20 swg
    Raypak 106k, Dolphin s-200, Taylor k-2006c, Taylor k-1766, Speedstir, Little Giant cover pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Pool store and my test.
    It is very unlikely that your CH is 0. It is also very unlikely that your TA is 35. The CH test can be tricky. More detailed instructions here, Pool School - Extended Test Kit Directions
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    My test kit reads CH in my tap water. But will not with pool water. Is it the water temp?
    BTW the pool store computer says "Adjusted" Total Alkalinity. That tells me it is
    not the true reading?
    DFW, TX
    24,974
    No, water temp does not impact the CH test. FC does not affect CH or TA tests. Only pH is impacted by FC above 10.
    More about adjusted TA here, Nine (9) Adjusted Total Alkalinity Questions
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    Quote Originally Posted by pooldv View Post
    Exactly what I thought. ATA means nothing to me. Pool store gibberish.
    domct203's Avatar
    Jun 2015
    CT
    3,900
    A CH of 0 is strange indeed. What is the tap water CH level?
    How old are your test kit reagents?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    My reagents expire 1/18 - 3/18. I will be checking again today. Tap water was 140ppm
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    The bottle is blue. The TA green bottle is still clear compared to the CH reagent. I wonder if my CH is bad? I know with my pool it doesn't much matter. It is just a mystery that is driving me nuts! LOL
    DFW, TX
    24,974
    It is normal for the CH reagent to get cloudy and act a little weird. Be sure to shake it well. Try the 25ml sample for higher accuracy.
    Yes, pool store gibberish is the perfect description.
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    I just tested CH again. 20 drops r0010 and 5 drops r0011L, water stays blue after 5 drops. I added a little calcium to my test water and it turned pink/red. Tap water turns pink/red. Pool water stays blue. I added 8 lbs. of calcium last week to see if it would read and nothing.
    30,954
    Your description of your test method is a little vague. You make no mention of the R-0012 by name. Are you comfortable you are doing the test correctly?
    How did you add "calcium" to your test water?
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    My understanding is once I see blue the test is over after 5 drops of r0011. If not, I might be doing the test incorrect.
    I added a 1/4 teaspoon of calcium to a condiment squeeze bottle of sample water. It turns red after 5 drops like my tap water. Actually less than 5.
    30,954
    Calcium Hardness test - Too much CH in all pools is harmful........vinyl, fiberglass or masonry. It can cause cloudiness in your water or scaling onto pool surfaces. Too little CH only affects masonry pools as it can leach calcium from the walls or grout. CH readings in the 250-400 range are considered ideal.
    1. Rinse and fill the clear plastic cylinder to the 10ml mark
    2. Add 10 drops of R-0010 and mix. Then, add 3 drops of
    R-0011L and mix. Red indicates the presence of Calcium.
    3. Add R-0012, one drop at a time, ‘til color changes to blue. Multiply number of drops times 25. NOTE: If the pool water contains known copper, add two drops of R-0012 PRIOR to adding R-0011L and continue. Count the two drops in your R-0012 total. Record.
    Are you following the above directions precisely?
    JoyfulNoise's Avatar
    May 2015
    14,092
    If calcium is present in the water then the CH test will turn reddish-purple after adding the R-0011L. When you do the titration with the R-0012, you must titrate until the sample has turned blue and STOPS CHANGING COLOR. In other words, the end point is when the blue stops getting more blue, not when you first see it turn blue.
    Also, what chemical are you using to "add calcium" to your water? Is it pure calcium chloride?
    Matt
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    I am doing the 25ml with 20 drops r0010, then 5 drops r0011L. There is no red to turn blue. After r0011L it is blue.
    Yes, I used calcium chloride. I have not added 2 drops of r0012 first. This may make a difference if the algaecide used to close had copper. I'll try it.
    Thanks
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    But you got an indication of CH in your tap water? This is the same water as the pool fill?
    Essential Links:
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    After shaking my r0011L for about 30 seconds I got a faint purplish blue. Took 24 drops to get it to the blue I had been seeing. So I'm thinking I may have finally got a reading of 240.
    Thanks for all the help.
