Thread: replacing some polaris 180 pieces
    Jul 2016
    edmond, ok
    11
    I am replacing some worn or missing pieces of my polaris 180. It is 10 years old and works well, just wearing in spots. One thing I am replacing are a couple missing screws that have backs out and been lost. I fount some on amazon that were about 9.50 a piece. Then I found these that appear to be the same...https://www.amazon.com/Machine-Screw...Steel+Pan+head.
    Will these work? 50 for $10 is way better deal.
    Thanks
    20x40 in ground rectangle with small sun deck and spa with spill over. Pentair pump, Intellichlor IC40 (no longer working so have changed to chlorine)
    Apr 2016
    TX
    51
    Re: replacing some polaris 180 pieces
    Hi Jberrymd,
    You'll need to verify the threads are the same. It might be easier for you to take the screws you're trying to replace and go to a big box story and compare threads. They often have in the screw and nut aisle gauges for you to use to see which thread and size you have.
    Good luck!
    -Mo
    Mo - 21K gal, IG plaster, dual Pentair SuperfloXF pumps, 72 sqft DE filter, cartridge filter for the spa, dual Waterco multi-cyclone prefilters, Dual Circupool SWGs, Polaris booster and cleaner, TBD custom controller.
    Jan 2012
    'burbs of Augusta, Georgia
    8,577
    If you can find the schematic for the Polaris180 online that should list the size for the screw.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
