Results 1 to 7 of 7
Thread: Pool deck control joints
    Dec 2016
    Austin, TX
    115
    All,
    I am considering pour in place decking/coping. My last pool had that, but did not use the foam forms. It turned out not that great.
    This time, I plan to use Stegmeier forms.
    On my last pool, the deck joints were sawed in after the pour. There was some minor cracking, but nothing too bad.
    This time, I am thinking of doing a salt finish concrete deck, that will be scored in a 24"x24" diamond pattern.
    Do you all think I can get by with only scoring the concrete?
    I remember older pools always had those plastic joints all over the place.
    Thanks
    Nov 2011
    Moberly,MO
    1,025
    Re: Pool deck control joints
    Cardinal Z form is a much better coping edge form than the Stegmeier form. Especially if you have straight walls to pour
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Apr 2013
    Sacramento, CA
    2,769
    Are you putting mesh or rebar in?
    If you score in some lines that should work. I haven't seen your project and don't know all the details but in general that's not a bad plan.
    Just realize many of the scored lines will shortly become full cracks. And in Texas you need ta allow ffor the deck to expand horizontally on those hot summer days
    Dec 2016
    Austin, TX
    115
    I started a build thread for the whole project. Here it is.
    New build in central Texas
    Dec 2016
    Austin, TX
    115
    Quote Originally Posted by swimcmp View Post
    Why is that? What is the cost difference?
    Most of the pool is curved. Some areas are straight.
    Dec 2016
    Austin, TX
    115
    Quote Originally Posted by gwegan View Post
    Probably rebar. The deck will be 12"-20" above grade. About 2,000 sq-ft under patio roof. About 1,000 sq-ft around pool. Areas separated by a channel drain. All poured at once.
    Nov 2011
    Moberly,MO
    1,025
    The Cardinal form does not bow and wobble on straight walls as it is plastic. The stegmeier form has a tendency to dip and bow between ties. Cardinal also makes a bendable version of the Z form.
