- Feb 6, 2015
- 6,065
- Plaster
- CircuPool RJ-45 Plus
28 sounds a bit high. When the pump is off, does the gauge read zero? If so, you may want to clean the cartridges again. I know it's a pain to open the filter up again, but knowing the clean pressure is important.
In case you don't already have it, I think this is the manual for your filter: PENTAIR SYSTEM 3 S8M600 OWNER'S MANUAL Pdf Download.
You may want to contact InyoPools about the replacement cartridges. They are very good about identifying needed parts.
If the air went away after replacing the leaf vac o-ring and then came back after you opened the leaf vac and pump, try to re-lube both of those o-rings again. You don't need much lube. And check to be sure there isn't any dirt or debris on the matting surfaces - take the o-ring completely out and check. Also, check around the tabs on the leaf vac for any cracs again. Don't overtighten the lids either.
The water looks good. Looking forward to a complete set of test results when your reagents arrive.
EDIT: Here's a link to cleaning a cartridge filter that may be helpful. It's an older thread, so please don't respond to it directly. Re: How to clean a cartridge filter
