Thread: Cleaning with Nautilus Plus always seems to dirty the pool more
    Mar 2017
    Happy Town
    1
    Hi, I have a Dolphin Nautilus Plus and I don't use it much because whenever I do the gunk I try to use it on just simply seems to go in and out the robot spewing the stuff around and turning it into a cloudy mess even with the ultrafine screens included with the robot. Is there some way to adjust it or a better attachment that will actually catch the gunk or do I have to use something else?
    Apr 2015
    Church Point, LA
    10
    Re: Cleaning with Nautilus Plus always seems to dirty the pool more
    Welcome to troublefreepool.com. Add your pool type/size in your signature so everyone knows what you are working with. What kind of gunk or you trying to catch? Have you done a water check? Post your results here. It seems like you are trying to catch particles smaller than the Nautilus is capable of filtering.
    Intex 26' x 52" (14.5k) Intex SWG. 14" sand filter. Taylor k-2006 kit
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,263
    N,
    Welcome to TFP... A Great resource for all your pool questions...
    Sounds like you are trying to capture algae, which no cleaner will do.
    What kind of number do your test show? What does you water look like?
    FC
    CC
    pH
    TA
    CH
    CYA
    Thanks for posting,
