Results 1 to 10 of 10
Thread: Is algaecide always needed for pool opening?
    Jun 2015
    Ottawa/Ontario
    357
    Title says it all...
    20000 gallon, Vinyl liner IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    Re: Is algaecide always needed for pool opening?
    Nope. In fact, it's only useful if you are closing your pool.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jun 2015
    Ottawa/Ontario
    357
    So just chlorine, and adjust pH & alkalinity then...and clean..? Thanks!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,315
    Remember, you need to know what the CYA level is, to know what to target for FC level.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,892
    Quote Originally Posted by tlevy View Post
    and clean..?
    Is it clear and just needs vacuuming or is it a green swamp?
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    We almost never suggest it, and some add a good amount of undesirables like Copper which will stain your pool with surprisingly little use.
    Are you set up with a good test kit and familiar with Pool School?
    Essential Links:
    Jun 2015
    Ottawa/Ontario
    357
    I don't have the FAS test kit as it is not available in Canada. The pool is still frozen, so no testing of anything just yet.
    The kit I have is the liquid chlorine test kit from Taylor...not ideal by any stretch, but better than a dropper test.
    Jun 2015
    Ottawa/Ontario
    357
    Quote Originally Posted by tim5055 View Post
    Not sure yet...no reason for it to be green, as it was closed properly, well sanitized and properly balanced...
    May 2014
    Franklin, NC
    9,892
    Generally how it was closed is not the full determining factor. The bigger factor is when it was closed. If it was closed/covered when the water was still warm (above 60) the chlorine you put in it for closing will be depleted in a week or so due to any organic material in the water.. Then the algae has a chance to start growing. In addition when you open is just as important. If you wait and allow the water to warm under the cover then this is more time for algae to grow.
    We always recomend - Close late, withteh water the colder the better. Open early, again with very cold water.
    Support the site
    Jun 2015
    Ottawa/Ontario
    357
    Ok. I think temp was close to or below sixty. In a few weeks I guess I will find out!
