Thread: First Test K-2006
    Mar 2017
    Garland/TX
    3
    First Test K-2006
    Hey all yesterday marked the end of my contractor pool startup following my Stonescapes resurfacing and today marked my beginning as a TFP disciple. I think I'm in pretty good shape following my first test results. Is there anything I should be paying really close attention to? Here are the results:
    3/31 5:45p
    FC = 10ppm
    CC = 0
    PH = 7.4
    CYA = 50ppm
    TA = 100ppm
    CH = 330ppm
    15k IG Freeform Midnight Blue Stonescapes. Pentair FNS Plus DE Filter. Pump unsure. Garland, TX
    40,893
    Re: First Test K-2006
    Welcome to TFP!!!
    Those numbers do look pretty good!
    The FC is slightly high, just keep it above 4ppm (targeting 6-8ppm daily).
    Everything else is good.
    Long term:
    You will want to keep your pH in the 7.4-7.7 range and hopefully your TA will drop a bit.
    Due to evaporation, your CH is going to keep climbing making keep the pH in line more important.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,323
    H,
    Welcome to TFP... A Great resource for all new pool owners...
    As Jason has said your numbers look pretty good. But my question is are they going to stay good???
    I ask because you already have a CYA of 50 ppm and you don't say how you plan to chlorinate your pool.
    If you use 3" tabs, you can expect the CYA to steadily increase to an unmanageable level.
    So... how do you plan to chlorinate going forward???
    Thanks for posting,
    Mar 2017
    Garland/TX
    3
    Quote Originally Posted by Jimrahbe View Post
    H,
    Thanks for posting,
    I'm going to stock up on bleach in the morning! Disciples don't tablet!
    Jul 2014
    Bedford, TX
    9,323
    H,
    That sounds like an Amen to me....
    Thanks for the follow up.
