Results 1 to 7 of 7
Thread: Which test kit??
    IrishEyesSmiling's Avatar
    May 2016
    Richmond, VA
    78
    Which test kit??
    Not sure which test kit to get. I know I'll want a speed-stir but what else? Contractor said he might start our install and deck build next week
    I plan to use the TFP method.
    My notes...
    Taylor K-1766 is the best kit to measure for salt levels
    TF-100 $70 also tests for CH and CYA and will last for 2 years
    Taylor K-2006
    Donít need CH for vinyl pool
    15'x30'x52Ē 12K gallon Wilbar Discovery/Innovation Resin AGP buried 2í w/ wood deck. Hard plumbed Pentair 1.5HP 2SP Dynamo pump, Pentair SD40 sand filter, Pentair iCHLOR 30 SWG
    500 gallon spa w/ ozonator using Dichlor/chlorine. TF-100, Taylor K-1766, & Speedstir. Dolphin S100 "Flůki". My 2017 Build Thread
    CLICK HERE to Become a TroubleFreePool Supporter! // AmazonSmile: You shop. Amazon gives.
    May 2016
    Richmond, VA
    78
    Re: Which test kit??
    Guess I should of said I plan to get the TF-100, Speedstir, and Taylor K-1766. I'm questioning whether I need the Borates and AquaCheck Salt tests.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    K-1766, TF100, and a speed stir and don't look back.
    Borates--not unless you decide to add them. No strips.
    Jun 2015
    St. Francisville
    78
    What the heck is a speed stir and why do I want/need one?
    30k gal, IG, vinyl, Pentair Tagelus TA 60D sand
    Jedisparky's Avatar
    Mar 2017
    L.A. CA
    101
    You want one cuz it's really cool and you feel like a mad scientist. It's basically a magnetic pill at the bottom of your tester that spins with the battery powered rotating magnet.
    Loc: So Cal Full Sunlight, IG 30'x15' Rectangle, 21,000gal w/ 2100gal Jac w/ Spillover
    (SWG) Pentair Intelli IC40, Pentair Intelliflo Variable Speed UEE Pump
    Pentair Mastertemp 400 Pool and Spa Heater
    Pentair Clean and Clear Plus Cartridge Filter CCP-420
    Intellibright 5G Color Pool and Spa Lights, Hayward Nav Pro Pool Vac, Taylor-2006
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Your best deal by far is a Bundle Package at TFTestkits. Thr TF100 is the best value for the dollar.
    Essential Links:
    Apr 2010
    East Texas
    10,158
    Quote Originally Posted by aralph View Post
    Sent from my MotoE2(4G-LTE) using Tapatalk
    Using the Speed Stir, my FC test consistently clocks in half a point lower than by swizzling the tube. Easier to concentrate on counting drops on tests requiring more and for a SLAM.
