Thread: Booster Pump
    7snorkel's Avatar
    Mar 2016
    Plano, TX
    51
    Booster Pump
    After giving me no problems, suddenly, I have a 3/4 PB4 booster pump that only hums for a few seconds, and then shuts off. I have taken off the back cover and spun the motor, so IT's not locked up.
    Took off the back plate and see the contacts are all clean. AND.... tried a new start capacitor, and it still just hums.
    any other suggestions before i write this one off?
    i didn't see a starter 'reset button' in the back, but maybe i missed it.
    thanks for your help.
    15K IG Plaster (1991), Pentair
    FNS 60- DE;Centurion 2.20HP, PB4 Booster Pump. spa spillover, Polaris 380, TF-100; SpeedStir​
    Apr 2013
    Sacramento, CA
    2,769
    Re: Booster Pump
    Dump it in the trash and buy a robot. It will drop your power costs to almost zero and will do a better job cleaning your pool. While the initial cost is high you get a cleaner pool and lower costs.
    You can take the motor to a shop and see if they have a solution but you have exhausted the normal dyi solutions.
    7snorkel's Avatar
    Mar 2016
    Plano, TX
    51
    Re: Booster Pump
    alright.
    i am going to replace or repair it myself...i think.
    i'm considering breaking down the old booster to see if it's repairable.
    While i do this, can i leave those two hoses from the volute open, and run the filter pump without water going everywhere?
    Thanks
    Apr 2013
    Sacramento, CA
    2,769
    Re: Booster Pump
    You can replace the motor without disturbing the wet side.
    As I said above this is usually not worth it in the long run. Booster pumps just end up costing cash.
