Results 1 to 16 of 16
Thread: How long do you run your pool pump?
    Feb 2017
    Orlando Florida
    13
    How long do you all run your pool system? I'm in central Florida which I'm sure varies from state to state. I run a PENTAIR INTELLIFLO VARIABLE SPEED 3HP pump... I know I can mess with the rpm and have it set at 2800 to run he pump generally. Thanks for any advice!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,329
    Re: How long do you run your pool pump?
    DK,
    I have a SWCG and run my Intelliflo 24/7, at 1,200 RPM, for less than $20 bucks a month. I do this because I like the idea of a little chlorine all the time vs. lots of chlorine in bursts.
    Here is what I normally say about pump run time...
    Each pool is a little different... You generally run a pump for three reasons:
    1. To keep surface debris moving and being pushed into the skimmers. The more debris the more often you need to run the pump.
    2. If you have a Salt Water Chlorine Generator (SWCG) you'll need to run it long enough to generate the amount of chlorine needed.
    3. To circulate the water to ensure the chlorine is effectively distributed throughout the pool. Two or three hours per day is all that is needed for this to happen in most pools.
    There really is no one answer that fits everyone, just do what works for you.
    Thanks for posting,
    30,964
    The very short answer is to run it long enough to keep the pool clean. I would suggest with your big VS pump you start at about 1800 rpm or less and run it maybe 12 hours daily.
    If the pool is really clean start bumping the timer backwards until you find the minimum time you can run and keep the pool clean. Each pool is different.
    mas985's Avatar
    Pleasanton, CA
    11,988
    I am going to be more aggressive than Dave and say you could run as little as 2 hours per day and as low as 1000 RPM but it depends on other factors.
    Do you manually dose or are you using an SWG?
    Are you running a floor cleaner?
    Are you running solar or a heater?
    How many skimmers are you running? - The lowest RPM should be where the water runs over the skimmer weir and not around the edges.
    Do you have a solar cover on the pool most days?
    Mark
    Apr 2016
    Riverview, FL
    351
    I'm across the state from you, I run my pump at 1600 RPM's for 11 hours/day. I have SWG and also screen enclosure. I figure I could go slightly lower but few bucks of savings per month isn't worth the risk of possible problems for me. I'd spend more in chemicals if I had to SLAM it for some reason.
    Free Form 13K IG (Quartz) w/Screen Enclosure - 2 Sheer Descents, 1 Bubbler - Hayward 60 SF DE Sta-Rite - Hayward SP3400VSP EcoStar - Hayward Aqua Rite AQR9 (T-Cell-9) SWG - Zodiac MX6 - July 2016 - Taylor K-2006 - Taylor K-1766 Salt Test
    mas985's Avatar
    Pleasanton, CA
    11,988
    Running your pump that long wont solve chemistry issues. The only reason to run it that long is for constant debris removal or perhaps a heater.
    Mark
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    I run mine 2 hours a day from a timer on weekdays and all the time during swimming on the weekend.
    single speed pump here.
    It worked well last season.
    Dolphin E10 Cleaning Robot.
    Apr 2016
    Riverview, FL
    351
    Quote Originally Posted by mas985 View Post
    Doesn't run time impact SWG output?
    mas985's Avatar
    Pleasanton, CA
    11,988
    Yes but the SWG should be sized large enough so it doesn't require such a long run time. I have no problem getting enough chlorine in a 20k pool with a T-15 in less than 2 hours. Yours should not be that much longer.
    I did a quick calc and a T-9 running at 100% for 11 hours is 3.85 ppm (13k). There is no way you should need that much FC added to a pool each day.
    Mark
    Apr 2016
    Riverview, FL
    351
    Based on Hayward specs, my SWG is sized to twice my pool size which appears to be the recommended sizing. I have to run at 50-60% in summer and with 11 hour run times. I can't see how my SWG would generate enough if pump was sent to run 2 hours. Interesting to hear that you T-15 produces enough for your 20,000 gallon pool with 2 hour run, learning something new every day.
    mas985's Avatar
    Pleasanton, CA
    11,988
    Then you could at least halve your run time.
    But what is your CYA level and the FC target you are using? If your CYA was at 80 ppm and FC target is 4 ppm, then that means you are losing close to 2 ppm per day which would be a 50% extinction level. That is very high. Pools with a CYA level of 30 ppm generally have extinction levels that high. My pool averages around a 15% extinction level at those levels which means I only need to add 0.6 ppm per day.
    Mark
    Apr 2016
    Riverview, FL
    351
    New build last year, PB recommended CYA at 40. Later, recommendations here suggested setting target to 50-60 (due to screen covering pool). Those CYA targets would account for my higher SWG %.
    After learning more and getting feedback from users here I've readjusted all my targets with CYA target now at 80 (FC target of 4). Pool does get lots of sun, southern facing so gets sun from morning until just about dusk. With CYA target of 80 I may be able to keep my SWG % lower. However temps in mid-80's now (water temps around 78) and SWG is already at 40% with FC holding pretty steady. But I anticipate as we get further into summer and with even longer sun time on pool I may still have to slightly adjust my SWG %.
    Always a learning experience here for me.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Not sure if you have a SWG or not, but I run my manual dosed pool around 4-6 hours per day. More if it gets pretty dirty, and its usually around 1600-1800 RPM. When we get a storm or bad wind, I'll run it more by turning it on and letting it go the default 12 hours 2-3 times.
    Reading around and learning on the forum, I got inspired to experiment, and was shocked how little I could really get away with. I'll add other runs to it while people are in, cleaning it and such, but some can really do fine with surprisingly little.
    Essential Links:
    Nov 2015
    Ok ok
    857
    Ever since I got my Pentair variable speed pump, I run 24/7 around 1400 RPM. In the summer my Auqua Rite SWG is on for about six hours a day at 30%. For my 14 K pool is perfect. Right now I have it at 20% and is doing fine, once it heats up I will increase to 30%.
    ~14K gallon - AquaRite AQR15 SWG - pool Newly plastered on April 9 2016
    TF100 kit - STA-RITE SYSTEM3 Modular Media Filtration - Model S8M150
    Pool water supply from on site water well = CH of ~350 and TA of ~350
    Doheny's Discovery Automatic Robotic Cleaner/Pentair Model 011018 VS Pump
    Sundance Altamar Hot tub separate from pool / central Oklahoma
    Akathisia's Avatar
    Jul 2015
    Davis, CA
    133
    3 hours a day about 1200 rpm gives me enough FC and a good skim.
    23k gal IG, plaster; IntelliPro 4 x 160 Variable Speed; STA-RITE S7M120 300 sqft cartridge filter; Intellichlor IC40 SWG; Pentair EasyTouch; Maytronics Dolphin Triton Plus robotic cleaner named "Domo" (arigato Mr. Roboto); Hot Spring Vanguard Spa, TF-100 test kit w/SpeedStir, SampleSizer w/Taylor Calibrated Cylinders and FlowVis Flow Meter from TFTestkits.net. Auto fill and Auto drain. Chlorine / CYA Chart
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,496
    I run mine at 200 watts for circulation/filtration
    Winter (not swimming): uncovered 6 hrs
    Summer: uncovered 8 hrs; covered 4 hours
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
