Thread: What pool light ?
    Apr 2016
    E.Bridgewater Ma
    34
    What pool light ?
    Wondering what's the best and easiest pool light to install in an above ground pool. Really don't want to cut or drill any holes. Are there more options?
    14,500K above ground Kayak with deep end. Sta-rite 100sqft cartridge filter with 1.5hp pump/motor. TF-100 test kit w/speedstir.
    Jan 2012
    'burbs of Augusta, Georgia
    8,549
    Re: What pool light ?
    Have you looked on Amazon? I found a bunch of them the other day that would work for you. Some worked by solar, some rechargeable, some attach over the side and some float.
    That's the place to look for a variety of lights. Have fun!
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    http://www.homedepot.com/p/SmartPool...NL50/205951976
    Its what I have, it works great. You have to pull a top rail to install it though. Once it's installed you don't have to move the top rail again.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Apr 2013
    Sacramento, CA
    2,769
    There are a bunch of lights out there. They all get mixed reviews on here and on Amazon.
    Spend some time and look. Talk to a few AGP dealers and see what they like.
    The battery powered ones are generally dimmer and don't last as long as the pluged models.
    Someone may come along and tell you about one they love -- but in the end most get mixed reviews.
