Results 1 to 13 of 13
Thread: Pool light shows plaster imperfections
    Dec 2015
    Dallas, TX
    41
    We just re-plastered with white plaster. Before this we only had the pool light on a few times. My recollection is that the plaster was quite smooth, but we did not like the glare from the light, so did not use it. We fixed the glare problem during re-plaster. But now with the white light on, the new plaster looks like it has "cellulite" - various small bumps and dips. Not a smooth look. The pool company says that is typical when some old plaster has been chipped out. Of course none of this is noticeable during the day.
    I know that lights, and particularly in white plaster, magnify any imperfections, but my question is - should the plaster be smooth as a baby's rear? I am less inclined to use the light the way it is.
    20K IG White plaster, deck jets, sun ledge w/ bubblers, 3HP IntelliFlo VS, Polaris 280, PF100 sand filter, IC40 SWCG, EasyTouch, ScreenLogic automation.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,884
    Re: Pool light shows plaster imperfections
    Even a baby has some imperfections LOL Yeah it is very normal for a replaster. Look at as landscaping and see what neat pictures you can make out of the dips and such.
    Kim
    Dec 2015
    Dallas, TX
    41
    But new pools typically do not have this problem? I can't imagine a pool light company putting a picture of my lighted pool in a brochure.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    My pebblesheen had some waves and dips in it visible when the light is on from day one. Our light attracts bugs so we don't turn it on very much.
    Dec 2015
    Dallas, TX
    41
    The attached image shows what I am talking about. Is this similar to the surface that others have?
    Jul 2011
    Arizona & California
    833
    Pool lights will always show the imperfections. It is virtually impossible not to have some slight "waves and dimples" of a plaster surface, but still be smooth to the touch. I am sure that your original plaster had somewhat similar conditions.
    It is true that some plastering companies can or will provide a more quality, smooth, and consistent finish, and some don't. Also, it can depend on the conditions, weather, when plastering, etc.
    To try and determine where your pool stands, you would have to contact other contractors and visit their recently plastered pools at night and compare with your pool.
    Aug 2016
    Pittsburgh PA
    345
    If you had water movement, you wouldn't see those imperfections. Run the jets when the pool light is on.
    18'x36' vinyl - 24k gal - Intelliflo 3hp VSP - Pentair C&C 420 cartridge filter - IC40 Salt - EasyTouch 8 - ScreenLogic - Raypak 406btu NG heater - Intellibrite 5G ligths - 4 deck jets - sheer descent - X-Stream Slide 2 - TF100 kit - opened spring 2017
    Dec 2015
    Dallas, TX
    41
    Good point about the water movement. We normally keep the pump RPMs lower. But if guests are over I can make sure the water is more agitated.
    Still... I will daydream about having smooth plaster.
    Sep 2016
    Dallas, Texas
    188
    My new plaster has the same appearance. No way for it not to when the gunite is smoothed by hand and the plaster on top is smoothed by hand.
    Matt- IG gunite pool and spa built Summer 2016: 32' x 20' overall with two 4' x 8' tanning ledges. 6'x6' attached spa with spillover. Depth 3' to 5' to 4'. 16.4K gal. Lueders Limestone retaining wall and coping. Equip: Pentair SVRS vari. speed pump. Pentair 60 sq. ft. DE filter. Pentair Kreepy Crawly Plat. cleaner. Pentair MasterTemp 400,000 BTU NG heater. 1.5 HP spa air blower. Nature2 Sanitizer. Taylor K-206C. My 2016 Build
    Dec 2015
    Dallas, TX
    41
    I ramped up the RPMs and turned on the deck jets. Actually the imperfections seem more noticeable with the ripples in the water. Now I am glad I did not spend the extra remodel dollars to move the light niche and add two in the side of the pool!
    What makes us more interested in using the pool light is that we replaced the old 500 W bulb with a LED bulb, so much less heat generated. Then my wife covered the inside top half of the glass lens cover with black tape. The light points toward the house, but now all the light stays in the pool and the light source is not that noticeable. It is a neat effect.
    Aug 2016
    Pittsburgh PA
    345
    Picture? Led is the way to go...both in the pool and throughout the house. It's the way of the future
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    I hate it in mine too but it's natural. It's also done purposely in industry to find imperfections in things like boiler tubes.
    They call it "shadowing." Works like a champ on any surface by laying a bright light on it.
    Essential Links:
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,837
    Bp, sounds like your wife has it sorted, but as someone who hates white light, just so you know, for $10 or so you can buy a gel lens of any color that fits over the light ring...blue is nice, yellow will attract fewer bugs. With led you can also get color changing bulbs. All give a nice atmosphere, none will hide the inevitable imperfections but might diminish a bit
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
