Thread: backwash hose?
    ta2dwonderwoman's Avatar
    Jul 2016
    fall river ks
    502
    backwash hose?
    getting ready to set up my first sand filter and swg as soon as I see a peek of sun ... Intex 2800 GPH Krystal Clear Sand Filter Pool Pump and Saltwater System
    I keep reading about backwashing...seems to have a separate hose (flat blue jobby I keep seeing) ... is that the only / best option or should I consider something with a bit more "backbone"
    just do not want to spend $20 on something and have it not be what I really need
    thanks in advance for any input!
    Windy ☆ 22ft round, 11,400 gal, intex ag vinyl, SF70110-1 Intex sand filter/2800 gph pump, CS8110 intex swg, city water, solar heater, TF100 test kit/speed stirrer, over the wall intex skimmer~fall river ks~SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math
    Jan 2012
    'burbs of Augusta, Georgia
    8,594
    Re: backwash hose?
    My backwash "hose" is actually PVC pipe that is about 6' long and goes behind my equipment pad all the way thru my fence into a dry creek bed.
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Feb 2015
    Chandler AZ
    1,061
    Re: backwash hose?
    You can look on eBay for a used fire hose in the diameter you need. Many of these hoses are basically brand new but are out of date code for use as a fire hose.
    If it comes with the metal ends, you can cut one end off, slip the hose over your backwash fitting and clamp it in place. The hose should outlast your pool......
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
    Aug 2016
    Lexington, SC
    7
    Re: backwash hose?
    Quote Originally Posted by proavia View Post
    This is what I did. When I bought my house the backwash was plumbed into the same underground corrugated plastic pipe that the house downspouts used. Whenever I would backwash it would back up and flow out of the bottom of one of my house downspouts. I had nightmares of my crawl space being flooded. I quickly disconnected that, got a 100' used 1.5" firehose that I can screw into the new 2' waste PVC on my multivalve. I had to get a special adapter as the firehose threads aren't the same as typical NPT PVC threads, but it works like a champ now.
    10,200 gallon vinyl liner
    1 skimmer and 3 returns
    1hp Pentair Wisperflo pump
    Hayward S244T sand filter
    TF-100 test kit
    Jul 2012
    Cary, NC (Raleigh)
    69
    Re: backwash hose?
    I haven't heard of the used fire-hose option! I may look into that.
    I've always had to use the flimsy 50' blue "hose" - and at best I usually get 1 year out of it before it just bursts at the seams and makes a crazy mess all over.
    It would have been ideal to hard plumb it underground to the curb right where the storm sewer drain is - but a bit too late now, and there are ton of electrical/phone/cable wires buried where I need to go.
    18x30 Freeform In-ground Vinyl Lined. 11,500 gallons.
    4 returns, 2 skimmers, 2 main drains.
    Hayward TriStar 1hp 2-Speed Pump. Hayward S244T Filter.Hayward Goldline Panel + SWG.
    Polaris 280 cleaner. AquaComfort 75k BTU Heatpump
    TF-100
