Thread: another Salt Generator Causing Cloudy Pool
    Mar 2017
    Edmonton
    2
    Re: Salt Generator Causing Cloudy Pool
    We too have a cloudy pool when the SWG kicks on. This started just recently (Have been using a SWG for about 7 years and have never seen anything like this. It is an indoor pool in the basement of the hotel so no sun light. A pool contractor said it was micro bubbles and we must have an air leak on the suction side of the pump. Pool chemical supplier has no idea! Thoughts ....
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,493
    Re: another Salt Generator Causing Cloudy Pool
    Welcome to TFP! Good to have you here
    There are many possible reasons for cloudy water, but my curiosity is whether you use dry acid or liquid hydrochloric acid to maintain pH.
    If you choose to use Trouble Free Pool Care (TFPC) you will improve your cost of operation and probably be able to always keep the pool open, although you may have a period of a few days up to two weeks with the pool closed to clean it up fully. You will need a recommended test kit to follow TFPC. For delivery in Canada, that means the Taylor K-2006C. If you have American friends who could bring one up for you, or you could get it delivered on a trip to the USA, you could get a TFTestKits TF100 which is the most frequently recommended test kit here. Either way you'll pay for it in a season with savings on pool chemicals.
    You used to be able to order through Amazon and get a K-2006C delivered in Canada, so try that first. If that won't work, you can order from the company that has a monopoly for Canada. Their order form is attached below.
    When I first started out, I enjoyed this thread: TFPC for Beginners
    Your pool is considered a commercial pool, so you would need to let us know the Alberta regulations for commercial pool water chemistry, and we'd be able to tell you if it's possible to do TFPC and stay within their regulations, which it should be, but you're probably bound by those regulations.
    Attached Files Attached Files
    12k IG salt; glass beads in plaster; K-2006C, K-1766, K-1106 and CCL test kits; Pentair Eco800 1.2HP VS; Zodiac SWCG 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; Other family pools 10K SWCG and 15K on liquid; PoolMath app subscriber; | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
