Results 1 to 10 of 10
Thread: Ic40 No Power
    Oct 2014
    San Marcos, Ca
    62
    Ic40 No Power
    I found my IC40 with no power today. It is connected to an EasyTouch and its own transformer, wired to come on with the pump. Diagnostics say No Comm. It is enabled in the EasyTouch with 35%. I checked the fuse on the transformer and its fine. There is 120v at each wire inside the transformer. The cord from the SWG to the transformer is connected fully. Any ideas?
    12,000 gallon IG plaster
    Cartridge filter
    Intellifo VS
    EasyTouch Controller
    Pentair SWG
    Jan 2014
    Brookhaven, MS
    45
    Re: Ic40 No Power
    Ouch. If the fuse is fine, I cant think of any other reason.
    Doesnt the transformer step it down to like 24V DC or something like that?
    18x36 25k Gal Inground Vinyl Pool
    300lb Sand Filter / 1.5hp Single Speed Pump / Intellichlor IC40 SWG / Polaris 280 w/booster pump
    Oct 2014
    San Marcos, Ca
    62
    Re: Ic40 No Power
    Yeah, it steps down to low voltage. Hope I don't have to buy a new one!
    Jan 2014
    Brookhaven, MS
    45
    Re: Ic40 No Power
    Test the red/black for DC and see if that returns voltage.
    Oct 2014
    San Marcos, Ca
    62
    Re: Ic40 No Power
    At the circuit board right? 0.04 VDC
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,296
    Re: Ic40 No Power
    Ryano,
    The DC output should be about 39 volts... and the little green "cell power light" should be on.
    Is your transformer inside your EasyTouch, or is it an external power supply?
    Do you know if the transformer is wired for a 220 volt input or 110 volt input.. (If 220 volts, then the blue or violet wires would be connected to the black wire)
    "No comms" is the failure you get when there is no power to the Cell. Either a bad PCB with no DC power out, or no power into the transformer... which could be the fuse (that you checked) or that the Pump/Filter relay inside the ET is not providing power to the transformer.
    If wired for 220 volts you need to make sure you have 220 volts between the two input leads to the transformer.. 120 volts on "each" one does not mean you have 220 volts between the two because you could be missing one phase.
    Oct 2014
    San Marcos, Ca
    62
    Re: Ic40 No Power
    It's an external power supply, not part of the EasyTouch. There are no lights on at all. Transformer is wired for 220, configured as you said, 220v between the two inputs. There is power to the transformer. Looks like I need a new board.
    Jul 2014
    Bedford, TX
    9,296
    Re: Ic40 No Power
    Ryano,
    I would also suspect the PCB, but it would not hurt to rule out the transformer.. If you can test the two output leads going to the PCB there should be some low voltage AC, I don't remember the exact amount but I would think around 24 to 40 volts DC..
    Oct 2014
    San Marcos, Ca
    62
    Re: Ic40 No Power
    DC, not AC right? Which are the output leads going to the pcb?
    Jul 2014
    Bedford, TX
    9,296
    Re: Ic40 No Power
    Ryano,
    No, the output of a transformer will be an AC voltage. The transformer just makes the 220 volt AC input into a smaller AC output voltage. The PCB then makes the small AC into a DC voltage for the SWCG.
    On my PCB the AC from the transformer, comes in on J9 and J8... BUT... I have an internal power supply, so my board may different. You should be able to follow the two wires from the transformer to the PCB..
